I have a Sony kdfe50a10 Rear projection tv has sound but screen is not lit what could be causing this?Also can bulb be tested outside tv with multimeter?
    An expert whose answer gotĀ voted for 100 times.
  • 208 Answers
The lamp cannot be tested with a meter. The lamp is most likely your cause and should be replaced.
Posted on Apr 08, 2008
Tv nt coming on red light is on next to power light 50 inch lcd projection sony tv
hello. it sound's like you need to replace the lamp in your set. and here is how to do it the right way. rember to all ways unplug your set.. # 1 first. .Remove the outside lamp cover. The lamp cover is located on the right side of the Sony television. To remove the lamp cover, simply pull down. You will now have access to the lamp housing. # 2 Open the lamp housing door by turning the locking handle counterclockwise while pulling the door toward you # 3 Pull the lamp unit straight out of the television unit. Be sure not to touch the bulb, as it may still be hot. # 4 Slide the replacement bulb into the lamp housing. # 5 The lamp will slide securely into place.!!! "Do not" touch the new bulb as it will cause damage to the bulb and result in malfunction. # 6 Push the lamp door back into place. Turn the locking knob clockwise to secure the door in place.# 7 Slide the outside lamp housing cover back into place on the television.!!! plug your set back in to the wall & The television is now ready for use. thank you
Oct 21, 2010 | Sony KDFE50A10 50" HDTV
How do I replae a Sony Wega Model KDFE50A10 projection bulb
Lamp replacement procedure is written in user manual of tv in details, click Sony Support to download user manual copy that will help you to replace lamp.
Sep 10, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
optical block is famous for causing that sympton in a Sony
Jun 19, 2010 | Sony KDFE50A10 50" HDTV
50 inch lcd turns on for about one minute then turns it self off
Sony KDFE50A10 shuts down after 1 min is most likely bulb failure. XL-2400
Normal after a few years of use. Only test is to replace bulb. If in Canada look here:
Sony Gallery
Feb 28, 2010 | Sony KDFE50A10 50" HDTV
Sony rear projection tv
How long have this tv had it picture bulb,change before for this tv?Longtime usage,picture bulb the first,must change.
Nov 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
Apr 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Nothing displays on screen
the bulb maybe burnt out, I had a similar problem only no audio. The odd thing was that the lamp light was not lit indicating the bulb was burnt.
Dec 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Not sound or picture from the TV
If it has been over 2 years on this bulb, I would start there cause it will need one soon anyway.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. However, this is one of the model that Sony has class action lawsuits against them on because it has so many problems with the light engine. See this:
Jan 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
Top Televison & Video Experts
