Question about Optimus H-4436 Electric Heater
Every time i turn on my heater, the alarm light goes off and the heater will not turn on.
  • 36 Answers
I would buy another heater unless, that one is new and try to return it..
Posted on May 28, 2010
Hurlcon MX 250 Pool/Spa heater. Why does it have an intermittent F2 alarm (high temp >45d)?
check the manual bypass inside if ok check the temp sensor also check gas pressure if too low will overheat and shut off
Dec 31, 2015 | Pool & Spa
Why does my Kozy World natural gas wall heater set off fire alarm system?
Most new heaters give off a smell or some light smoke which needs to be burnt off the first time it is used it may smoke , this may be why your alarm is going off , run it with a window open to remove smell etc .
Feb 12, 2013 | Heating & Cooling
The low voltage light/alarm is going off
get your altenator and battery checked
Oct 30, 2012 | Electronics - Others
Alarm started and will not switch off. Siren goes all of the time unless circuit breaker furthest to the right is switched off, then lights and water heater do not work. The alarm was not operated, in...
open the fuse box and look at the outlet side of the circuit breaker ,then remove all the tails and then connect them one at a time so you can isolate the alarm feed and leave that disconnected
Jul 19, 2011 | Car Audio & Video
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Skoda Octavia Ambiente 2004 1.9 tdi, automatic gear: Problem1: board alarm, Glow plug system remains on at starting and contiune to flush in running. Engine starts hardly second or third time. Problem2:...
problem one is the timer control for the heaters ,also check the heaters that they are working ,oil problem ? look under the rubber boot that goes over the oil switch ,pull it back and if oil under the cover renew the oil switch,these motors do suffer from heater light flashing on and i know people have spent megabucks trying to cure it ,its a fault with dash and printed circuits ,but the heaters are not coming on i know because i have driven one with the heater circuit light coming on and i had a extended light on a long wire and the heaters are not coming on ,ignore it just renew the faulty glow plugs,as for EGR valve just pull teh vacumn pipe off the ERG valve and leave disconnect ,more hassle than its worth changing it ,you could end up with a ECU computer .Still a nice reliable motor though and economical
Jan 21, 2010 | 2004 Volkswagen Golf
Interior lights stay and alarm goes off every time i lock it
Your car thinks a door is open , thus the light stays on. When you lock the doors with the remote it activates the alarm system. 10 sec later it senses that the a door is open and alarm sounds.
I have a 99 passat as well and I just went outside to see where the switch on the door is. Can't see one anywhere , it must be inside the door (part of the latch mechanism). I tried to arm the alarm system by locking the doors with the remote while the door was still open , sure enough the alarm went off about 15 secs later.
Nov 05, 2009 | 1999 Volkswagen Passat
Alarm light staying on.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Feb 22, 2008 | Heating & Cooling
Optimus H-4436 Electric Heater Logo
361 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
