Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
Panasonic PT-61LCX65 My TV flickered one day until I changed channels. The next day the same sequence until i shut it off. When I turned it back on the scren was black but everything else powered up. Should I buy the whole replacement bulb package or should I first try replacing the lamp only? Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Most likely the lamp will correct this issue.
Posted on Apr 08, 2008
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Red spot on screen
Got the same problem with same TV (PT-61-LCX65) that was bought 4 years go in 2006 - first red spot appeared, then few weeks ago got green one nearby. Fixed it for free.
I called Panasonic using the phone number in the manual (1-888-843-9788), selected Service, told that I got the problem which is most probably "a manufacturer's defect" that should be fixed for free - they redirected me to next step, then to next one and in about 20 minutes they arranged me a home-visit by support person (the guy had to drive 2 hours to get here!). Every thing went _very_ smoothly, I am very satisfied with Panasonic's support, it was just one call with few redirections.
The service guy came in two days, unscrewed back panel, connected some kind of box to one of the boards (eeprom programmer?), turned TV onto some channel and let the box do its job for about 5 minutes - then all of a sudden spots disappeared and picture is OK now. The service guy told me that the overall picture quality should have also improved all across the screen, I guess TV sends some kind of feedback to that box for optimization.
It was free service, the service guy mentioned something about law action and that Panasonic is required to fix that for free.
Jun 11, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
Aug 09, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
LAMP HOURS
Sure.
Make sure the set is off but plugged in. Hold the "volume down" button on the set while pressing the "tv/video" button on the remote (at the same time) over 5 seconds.
This is a "customer" service mode where you can't screw up the set but can get some basic info on your unit. You cannot change any internal info in this mode.
Hit the "power" button when you're done and leave set off for 10 seconds before turning back on to reset your tv.
Good luck, Mark
Jun 10, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Please send me the instruction on lamp replacement
sorry I dont have the instructions for panasonic. but it should be straight forward remove the back and the lamp housing should be right there.
Mar 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic projection tv
call panasonic, bulb blown under warranty for 18 months the bulb is 284.00 just had mine replaced. it's a little over a year old
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
