Question about Kenmore Elite HE4 Electric Dryer
Burning chemical smell coming from the gas dryer
There is a chemical burning smell coming from the gas dryer. We are having wood floors put in our house and the fumes from the stain and poly was my original thought of the source of the smell. Now I'm not so sure. Our clothes and towels that have been dried smell bad. What is the cause of this?
  • Kenmore Master
  • 43,501 Answers
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
Posted on May 28, 2010
Why is there a strong gas odor?
Suggest you turn off the gas supply immediately! and check for a poor connection or other cause. Do not attempt to light the pilot again until the cause of the leak has been found and repaired!
Nov 19, 2015 | Home
Clothes come out of my gas dryer with a slight chemical smell
In my years of experience, the only situation like this resulted when painting had been done within the last 12 months. The flame burns off the VOCs. Beyond that, it's a stumper.
Apr 20, 2014 | Maytag MDG2706A Gas Dryer
I have just lit a coal fire for the first time in the living room, all is OK ecept when I went into the bedroom (2 floors above) I could smell smoke quite badly Any advice?
The chimney needs to be 3 feet taller than the highest point of the house . If you are running the clothes dryer, bathroom vent fan, or exaust hood in kitchen it makes a vacum in the house that can draw smoke into the house down the chimmney . I think when you burn wood or coal in a house it is pretty hard not to be able to smell it. Our house and clothes do not smell like smoke any more since we stopped burning wood.
Feb 02, 2011 | Heating & Cooling
The dryer puts off a chemical smell on the clothes-gas dryer
If it smells like gas on your clothes, your exhaust vent is probably being restricted, causing the exhaust to back up into the dryer cavity. Remove exhaust hose, make sure it is clear all the way to where it exits your home.( sometimes birds build nests in the outlet vent) Look into vent where hose attatches to dryer, and make sure it is clear also. If you smell gas when moving the dryer, there should be a shutoff valve near the wall, close it. DO NOT THE DRYER ! ! Call someone qualified to make the repair.
Feb 08, 2010 | Maytag Dryers
Gas emergency heat pump comes on with chemical odor
If the emergency heat doesn't come on very often, it will burn off debris that has collected on the heat exchanger causing the smell. Also, check that there aren't any chemicals that are being stored around the unit that would put out fumes that can be drawn into the system and when heated, cause the odor.
Mar 31, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Frigidaire gas front loading dryer smells from gas.
Your gas dryer uses a lot of air, not just the air that blows out the vent but the air used to burn the gas ( natural or propane ) as well, This is sometimes caused by the filter not being completely clean. By this I am referring to the clogging of the screen from the use of fabric softener sheets. The chemicals in these sheets will, over a period of time, impair the air flow through the screen and cause the gas odor to become prominent not to mention the temperature to rise within the dryer. you can clean the filter with soapy water and a tooth brush about every other month and it keeps this from occurring. but if after that the smell gas continues ...turn off the gas valve to the dryer and call for service!
Feb 21, 2009 | Whirlpool GGQ8831L Gas Dryer
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Amana Dryer Omits Kerosene like odor
it sounds like the orifice is gone bad
Jun 28, 2008 | Amana Dryers
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
Strong odor after staining floors
Is it possible that some finishing paint or what not have leaked onto the venting? And every time your dryer is turned on the venting heats up and evaporates the finishing stuff? If it is a considerable amount then it may take a while to completely eliminate the odour.
Aug 09, 2007 | GE DBXR463GB Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
266 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
