Question about Brother HL-2070N Laser Printer
Printer says no paper in tray..but there is. Have removed tray and checked for any obstacles, can't find any. Pls. help, printer is desperately needed on the weekend and time is running out.
  • 241 Answers
There is a paper sensor that could be malfunctioning. I would recommend taking the printer in for an assessment to see if the sensor has been damaged or needs cleaning.
Posted on May 28, 2010
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Printer screen shows " Out
Hi tpuette
Be sure that the paper in the paper try rests within the guides. Also, ensure the that paper try closes properly and is not loose. Be careful also with the amount of paper you load into the printer, don't load too much into the tray or it may cause a paper jam.
Once the paper is loaded the printer may want you to confirm this by pressing a button, this will usually be a button with "OK", "Yes" or "Enter" printed on it. Check the little screen on your printer for such a message.
Hope this helps :)
May 15, 2011 | HP PS C4780 All in One InkJet Printer
Every time I try to print something, the paper doesn't pull from the tray straight. It pulls to the left side and crumples the sheet of paper so that it can't feed through the printer.
You do not state the type of printer so it is difficult to give exact instructions, but I know what your problem is. Something is stuck in the paper path on the right hand side, hence the reason is skews to the left because the left side is able to advance and the right is hitting the obstacle. If your printer has a paper drawer, turn off the power, remove all cords and the cartridge. Pull out the paper drawer and then carefully stand the printer on it's back so that you can see where the paper goes as it comes out of the tray. You will likely find your problem right there. If you can repost with an actual model I can give you a much better idea of how to find a paper jam but these instructions should help you.
Mar 26, 2011 | Office Equipment & Supplies
Printer making crunching noise when printing. trouble picking up paper from main tray. keeps asking for paper to be loaded in tray, when its full. help D
It is a hardware problem.Your printer roller & paper sensor are not working properly. So pls checked it from service center
Oct 13, 2009 | HP Photosmart 3310 Printer
Canon pixma ip1980 service error 6000.. it flashes 3 flash...indicates paper jam but there's no paper on tray... pls help? What's wrong with my printer?
you need to open the printer. it has sensors around it. the one that you need to check is in the left side when you are facing the printer. the one that is sensing the graduated circular part. Remove the left cover on the side. then remove the sensor with a philip screw driver and clean it. then place it back and turn your printer on. I hope to be of help to you. Let me know if this works. I did it on mine.
Oct 06, 2009 | Canon Office Equipment & Supplies
Minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Jul 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Sep 15, 2008 | Computers & Internet
Printer won't accept paper to print when starting to go though it just stops..
pls check the ff:
- leading edge of your paper, must be straight
- clean the feed rollers, w moistened cloth, maybe dirty thats why it is slipping
- check paper orientation, must be leveled to the tray
- did you changed any configuration under properties?? check also
we can start from this
pls mark my solutions if it does any help
Jul 30, 2008 | Canon PIXMA iP1600 Printer
Brother HL-2070N Laser Printer Logo
174 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
