Question about Sony KP-57HW40 57" Rear Projection Television
Sony 57" it just started to go quick flash of a blue screen, then back to normal picture, then starts to turn it self off. the amount of time the tv stays on becomes shorter and shorter.
  • 934 Answers
This is almost one I'd prefer not to answer because it's not good news and usually posters just kill the messenger.
In this particular model sony the focus block P/N 8-598-955-31 are common failures which can cause the flickering but not usually shutdown. Also a common failure is the crts used in making this unit and they are not economically repairable. The symptoms there are exactly what you've described, flickering then shutdown. The flickering is caused by current leakage in the crt and are especially prevalent in serial numbers beginning with 90xxxx. Sony even put out a bulletin on this issue some time ago and offered part warranty on the parts for replacement. That offer has since expired.
You can remove the lower front panel and expose the lower area of the crts and focus block. If you take the the rubber end of a screw driver and slightly tap on the neck of each crt while watching Tv you can confirm the described failure of the crt if it flickers as you tap. We techs call this the slap and tickle method but it is VERY effective in this case. This does not in ANY way rule out having it diagnosed by a qualified technician, which I strongly suggest, it simply helps in confirming the diagnosis yourself.
Sorry
Bill
Posted on Apr 09, 2008
I have a sony projection tv. Colors/piture not right
Replace convergence ICs and a 5 amp pico fuse on power supply. ICs are part number STK392-560.
Just be sure to use thermal paste on the ICs or they will self destruct in a short amount of time.
Jul 06, 2010 | Sony KP-57WS500 57" Rear Projection...
SONY KP57WV600-Turns Blue and then turns black leaving no picture
Blue picture tube in TV is bad and requires replacement by qualified TV tech.
Apr 29, 2009 | Sony KP-57HW40 57" Rear Projection...
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony turns on and off again
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
Apr 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
