Question about Dishwashers
The metal thing at the bottom of my dishwasher is
The metal thing (Heating Element) at the bottom of my dishwasher is rusting. The rust comes off on my knives. Any suggestions?
  • Dishwashers Master
  • 43,501 Answers
I would replace it... they are not that exspensive and not that hard to replace...
How to Replace the Dishwasher Heating Element
http://www.fixya.com/support/r4589084-replace_dishwasher_heating_element
heatman101
Posted on May 28, 2010
Teka dw655 f1
Is electric,gas or steam heated? :)
I'm joking..for a small DW should be electrical heated.
Can be. 1..no power provided to heating element
.2..heating element broken--easy to check with one tester
3.connections for that heating element can be rusted or broken
Good luck
Jun 30, 2013 | Dishwashers
I have condensation coming off the refrigernt tube that runs from condenser to freezer also ice build up on inside to the point of tearing the metal on inside back panel. What causes this ?
A side door heater is already defective.
It has heating element, it is there to dry any moisture build up around freezer door.
When it become defective, moisture or condensation occur, hence moisture is there.
Causing it to rust build or develope on the metal of the freezer.
Rust weaken the metal and soon tearing it.
Have it check by a service technician before it getting worse.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
All the glasses come out cloudy and the stainless steel knives have rust marks. I don't overload, use proper soap What 's going on?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Kenmore Dishwashers
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
My Maytag Quiet Series 300 is not cleaning my dishes very well at all. My glasses always have grit left in them (even with Jet Dry), my coffee mugs have film left in the bottom of them and now even my...
First problem: The film on dishes and glasses. Try another detergent. Manufacturers removed all the phosphates from dishwasher detergents and there are many complaints. I have had good luck with Finish Quantium tabs. Also have purchased Cascade industrial from Sam\'s online (still has phosphates).
Other problems you are experiencing with the 300 I have also. within 18 months of ownership the control board went out twice. The lower rack rusted through, the silverware basket had the bottom fall out, the door latch broke, now the control board is going out for the third time. I am not hard on a dishwasher. I have had models last 25 years before.
My final fix for my Maytag 300--I have ordered a new dishwasher, it will be delivered Wednesday. It isn\'t a Maytag.
Oct 16, 2009 | Maytag 24 in. MDB5600A Jetclean II...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
Kenmore 587
You may try the rubber gaskets and fasteners that attach your heat element through the bottom of the dishwasher body. This is the only full penetration of the shell involving metal that I see. You could see these fasteners if you remove the dishwasher from its current position, rotate it clockwise on its side and see the two cheapo pressed metal nuts on threaded studs that have wires attached. These keep that black metal loop on the bottom (inside the washer) in place. Remove wires, unthread pressed metal fasteners, check heater element for the rust issue (replace if needed) and reinstall new rubber gaskets and fasteners. Hope that helps!
Oct 09, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
Owen Barnes
