Question about Moen & One Handle Tub & Shower Faucet
When you turn the handle over to the hot side the water will stop coming out. What would cause this problem.
  • donjolley May 30, 2010
    Thank you for the information. That was what I needed
    to know.
    Scholar:
  • 81 Answers
Your control cartridge needs to be replaced. If the water is turned on by pulling on the knob you need Moen service part #1225B. If the water is turned on simply by turning the knob counterclockwise you need serviic part #1222. Try to turn the water on briefly after either cartridge is out to flush any debris that might be still in the body of the valve. Get the cartridge beforehand. the come with a handy removal tool.
Posted on May 29, 2010
I have a Shower/Tub Faucet with UPC marked on it as manufacterer, can you tell me the full name of manufacturer?
check other hot water taps to check hot water is flowing from the hot water system(tap on heater not turned off)
check faucet handle is put on in the right place --only 1/2 movement to the stop
check for blockage to the hot water side of the insert ( incorrectly installed )
still with problems --call a plumber
Nov 21, 2016 | Plumbing
Hot water is very slow coming out spout. Cold water comes out fine with good pressure..
the anti scald is adjusted too low. its located under/behind the handle. it usually has am allen wrench head. remove the handle and adjust it all the all the way to hot that should fix it. on some models you can remove the entire thing,but on some that will cause the handle turn 360deg because in some models its also the stopping point of the handle. hope this helps
Dec 11, 2012 | Jacuzzi Home
When the lever on my Vestige faucet is turned to the hot side, it chatters and stops running when the hot water reaches it.
It sounds like you have a foreign body in the hot line,turn off water both cold and hot disassemble handle assembly including springs and washers slowly turn on hot water to see if object will flush out,if not disconnect hot water supply to faucet the turn on water supply slow ly to see if object is in supply line.If that dosen't work you may have to call plumber it may be in supply stop or below it and you need a professional to handle that.
Jun 10, 2011 | Moen 7065ORB Vestige Single-Handle Kitchen...
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
I cannot figure out why my hot water no longer gets hot. I unplugged my timer 3 years ago and never had a problem. Now, no hot water unless timer is on and circulating.
Best solution is to remove the circulation-system crossover located under sink and see if problem is solved.
After removing crossover piece, try hot water tap.
Another way to check if this is the problem: Turn off cold water shut-off located above water heater. No need to turn off power or gas to water heater. Now, no water should flow when you turn on hot water tap because hot is turned off.
Open hot water side of double handled faucet. If water still comes out the hot side, then crossover is the problem.
After removing Taco crossover, you can still have the problem if a single handled faucet has the same type of crossover issue.
Repeat test to see if water comes out of hot side when water to water heater is shut off.
If water still comes out of hot side, then put ear against each single handled faucet and see which one has sound of moving water. That will narrow down the suspects.
Mar 27, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Upon installation of a one handle Moen shower valve, water flows immediately in the off position (6 o'clock position) then reduces as valve turns counter clockwise until fully off at 12 o'clock, then comes...
you need to adjust the little gear like..plastic part under handle..plus hot water must be on so that the pressure is balance..the cartridge also needs to be adjusted so water is off on off position
Nov 25, 2010 | Moen & One Handle Tub & Shower Faucet
Hot water does not come out
I pulled the water heater out of the rv and found the one way value broken and cloged.replaced with new one $9.12 and put back together.works great.
Mar 27, 2009 | Water Heaters
Not alot of hot water?
1st Check the temperature restricting coller behind the cover under the handle. It is used to restrict the flow of hot water to stop you from being scaulded.
2nd Those set screws will control the flow. Check to ensure both sides are open the same amount of turns. If the water pressure is good turn in the cold side.
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Moen & One Handle Tub & Shower Faucet  Logo
277 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
