Question about Microsoft Xbox 360 Controller
The right analog stick doesn't respond right away after being pushed, i have to push it hard for it to respond
    Problem Solver:
  • 13 Answers
Open it up slowly and gentle then see if there is anything stuck to the analog from the inside sometimes dust or other things hold the analog stick from being pushed or make a layer between the analog and the board button..
Posted on May 29, 2010
Left analog stick My Xbox left analog stick does
Analog stick might be bad and may need replaced. If you don't feel comfortable tearing it apart, you may want to look into a new / used one.
Oct 12, 2013 | Microsoft Xbox 360 Controller
I own a mad catz n64 controller and any time i push or hold any button (b,a, cs) it makes the character move slightly but endlessly to the right side, the control stick works fine, i only got this problem...
To remedy this, simply don't move the analog stick when powering on the system. When the system turns on, however the analog stick is set to be the default center so if it is moved, it is assumed to be the normal center position. If you have accidentally moved it while powering on the system, you can reset it but letting the analog stick reset to center and then press and hold START, L and R at the same time for three seconds.
Jul 18, 2011 | Nintendo 64 Console
Im on the level where its the second time that you go to rexus prime and im trying to pull in the imperial star destroyer and im using the force to put it in the correct position to start pulling it in and...
When they're all dead, do as Kota says and use your Force Grip. The camera will shift and two images representing your analog sticks will appear on the screen. Hold the left stick in the direction indicated. This will start turning the Star Destroyer's pointy nose to face you. This is one of the goals. The other goals are to tilt the nose upward or downward with the right analog stick. This part is pretty twitchy, so pay attention to with direction the game wants you to put it in. Also, be aware that the directions for the right analog stick are UP and NEUTRAL, not UP and DOWN. Once the Star Destroyer's nose is pointing the right way, the lights behind the sticks will turn green and it'll tell you to push the sticks up and then pull them both downward. Do it and HOLD them both down. Do not push them back up, despite what the image shows. Keep them hold down until the Ties get close and begin firing on you. Then let go and kill them again.
Feb 19, 2011 | Star Wars: The Force Unleashed for Xbox...
WHY IS MY ANALOG STICK DRIFTING EVEN IF I'M NOT USING IT?
it may be that it's stuck in a position try pushing it in to the centre and pushing down on it.
Dec 24, 2010 | Sony PlayStation Portable (PSP) Console
Ps3 controller with a mind of its own
there is a reset button on back of controller try that (its the little hole use paper clip to push)... if that dont work then chuk it...
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
Installing the analog joy stick on the PSP 3000
For the PSP 2000 and 3000...
The Naki "analog joystick" is actually a gel (or silicone) cap.
You push it on right over the original button to thicken and
round it off, giving you more surface to push around,
Aug 24, 2009 | Sony PSP-3000 Black Console
Issue with right analog stick - Xbox 360 Controller
I'm afraid I've had the same problem and I can shed a little light on it.
I've tried to fix this but to no avail. I have even transplanted the whole analog stick unit with one from a working controller to see if it will work but I have the same problem.
So, my conclusion the problem is not with the stick itself, but with the microcontroller inside the pad which takes the info from the stick.
I took the analog unit out, and plugged the pad into the computer without it , but STILL the vertical axis on the right stick was pushing up even though there was no input from a stick. It seems to be a fault with the pad, not the analog stick.
Aug 21, 2009 | Microsoft Xbox 360 Wireless Controller
Sluggish Analog Response
How about changing your controler settings, you can do this in the settings menu
Nov 08, 2007 | Microsoft Xbox 360 Console
L3 and R3 problems
L3 and R3 r yr analog buttons just simply push down on them
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Controller Logo
921 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
