Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
How to replace coil string - Yard Machines 158cc Push Lawn Mower #11a 034f200
  • 61 Answers
This is best done with two people. Remove cover, place down so you are viewing the rope pulley. Remove all old rope. Measure 8 foot of new rope. line up pulley rope hole with rope opening in cover. Wind rope pulley 6 turns. Push new rope thru both rope openings, one in pulley and one in cover. Pull rope thru pulley and cover. Tie knot in pulley end of rope, Slowely release rope so it rewinds onto pulley. Install hope handle, your done. was'nt that easy? You will have extra rope, this is needed to go from engine to handle support on your mower handle.
Posted on May 29, 2010
Pull string
you might have you coil set to close to the flywheel and the coil is not letting the flywheel spin like it is suposto sotheir for you string id to tin\ght when you hace the hood on so reagap the coil and sett it a little farther back from the flywheel by not to far back
May 14, 2013 | Mtd 22" Yard Machine Push Mower
Coil
Here is a link you the IPL, shows complete brakedown od machine.
Aug 18, 2012 | Husqvarna 128CD 28cc Gas Line Lawn Trimmer...
I have a mcculloch string trimmer with no spark? Do I have to replace the iginition coil ? No spark at end of spark plug wire.
I am assuming you held the wire near the engine while trying to start it? If so then you need to either replace the ignition coil or hopefully just the spark plug wire.
If the wire is broken it won't spark either. You can check the wire with a multimeter set to resistance (ohms) and check for infinite resistance, if you get infinite then the wire is shot.
Jun 07, 2011 | Solo 2 Cycle Curved Shaft String Trimmer
Hi I have a mtd yardman 55/45 ym 5518 s mower and the string has snapped. I can see how to thread in back through but cannot coil the string around, is this possible to do?
wind the coil 4 the string until it is taught hold it and thread line into it the recoil on the spring will pull it in a bit futery but persavere
Aug 17, 2010 | Yard Man Garden
Heating element. How about just replacing the coil?
you can get a re-string kit if its the open type heating element round pan style and re-string it yourself for about $30-$40
May 27, 2010 | Dryers
Square D (Nelco) MWA 2420 Forced Air with a broken heating coil
if its a coiled "nichrome"wire,get the wattage off of it and order a re-string kit from an appliance parts retailer and re-string it yourself,if its a solid-element as in an oven bake element then go direct to the company web site for replacement cause its probably a special shaped element
Nov 19, 2009 | Dryers
String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Nov 05, 2009 | Garden
How to put the string back into the coil
A lot of people don't even bother trying to fix a recoil because they don't cost much to replace. maybe $10. but if you try make sure you don't let that coil unwrap or you will have a lot worse problems then just the string :p
If you can successfully get the cover off without allowing the coil to come loose then simply just wrap the string back up.
Jun 28, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
292 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
