Question about Clarion SRV303 Car Audio Amplifier
How do i install a clarion active subwoofer base enhancer to my car sterio, i know its two wires but which two on the fusion head unit is it can you please help me
  • 239 Answers
All u need is the blue/white its the rem
Posted on Aug 16, 2010
My head unit has permeant live, i have tried swapping red and yellow around its know of red on red and yellow on red... i have to remove cover and disconnected ipod any help
well it depends on the car, if its a sunfire, theres a yellow wire that connects to the red wire that connects to the sterio, that yellow wire goes to fuse box maybe the power is constint the only way to fix that is to hock the red on sterio to an ignition source,
Sep 21, 2010 | Alpine Car Audio & Video
Tip
No audio even though sterio wires are all connected
My 1997 Alpine CDE-7828's wiring schematic doesn't disclose one important thing for many older and possibly even some newer sterios (aka 'head units'). If all wires are connected per the sterio's schematic andf sound is missing, you probably have a dedicated pin on yout vehicle's harness/connector that will read something like 'Turn-on AMP signal", <br />until you jumper the ignition hot lead (between the harness plug and your sterio) to your vehicle's 'Turn-on AMP signal' pin/connector wire (add a wire if none is supplied in your vehicle's connector), you won't get any sound even though all the other wires are connected per your head unit''s instructions.
on Nov 06, 2010 | Car Audio & Video
I HAVE A 1994 BUICK GRAND SPORT. I WANT TO HOOK A STERIO UP BUT THE STERIO THAT CAME WITH THE BUICK HAS A DOUBLE COMMPONET SET UP . HOW DO I BYPASS THAT AND HOOK UP THE CD PLAYER TO THE SPEAKERS?
1) Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system. 2) Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires. 3) Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers. 4) Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation. 5) Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them. FOR more help click on this link directly http://www.ehow.com/how_5829_wire-car-stereo.html ------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 25, 2010 | Car Audio & Video
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Sep 08, 2009 | Fusion FEW12PK Car Subwoofer
Hi i have fusion sub woofer can u help me to install just let me know how to install many wires so dotn know who to install in my car
  1. Batt + or B+ or Positive.
    This is the connection directly to your automobiles battery. It should be a fused connection rated to about 15% higher than the fuse installed in your amplifier.
  2. Negative or '-' or Ground.
    This wire should be just as thick as the 'Batt + or B+ or Positive' wire. This wire can attach to any solid clean metal connation in the vehicle. Usually a trunk latch.
  3. Remote or amp startup wire.
    This wire is a thin 12V wire that will come from the deck. It's a signal wire that tells the amplifier to turn on.
  4. Inputs
    Low level inputs are in the form of RCA connectors and will require that your deck or head unit has low level or RCA outputs. High-level inputs are used for stereos that don't have low level or RCA outputs. They work by taking an audio signal directly from the vehicles speakers and then amplifying it as necessary.
  5. Speaker connection.
    Match the + and - these with the appropriate connectors on the speaker box. Red means + and Black means -.
    I hope this helps.
Jul 06, 2009 | Fusion FEW12PK Car Subwoofer
I need the wiring diagram for this deck (vrx745vd)
Go to www.clarion.com click united states...then type vrx745vd and look to your right...you can download..
May 10, 2009 | Clarion VRX745VD Car DVD Player
Wires
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
Fusion sub..
check the impedenc on amp and speakers.if speakers have lower ohm the amp cant push them also can cause damage to amp.how do you have everything wired must be specific.high level inputs,rca,.how is the radio and amp wired together,where are you getting power sup[ply from and how?
chriszambrotta@yahoo.com
Jan 09, 2008 | Fusion FEW12PK Car Subwoofer
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
Car Audio & Video Logo
73 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
