Question about IBM NetVista PC Desktop
I need the user manual with pictures to connect all the cables
I need the user manual to connect all the cables and hard drives can u send me a manual?
  • 30 Answers
You can get soft copy of user manual from below mentioned link:
moz-screenshot-3.pnghttp://www.transferbigfiles.com/e5486bf3-0637-42fb-a074-99fc4b960b65?rid=FvgAtyB2d1ORiKhjXpkzlQ%3d%3d
Posted on May 28, 2010
Nkodak instruction manuals
You may download the User Guide at http://resources.kodak.com/support/pdf/en/manuals/urg00732/Z1275_Z1285_UG_GLB_en.pdf and the Extended User Guide at http://resources.kodak.com/support/pdf/en/manuals/urg00731/Z1275_Z1285_XUG_GLB_en.pdf
You might want to consider NOT connecting your camera to your computer. The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
May 23, 2014 | Cameras
My Iomega mx mobile mass storage player has stopped sending signal through HDMI cable to TV all other functions are ok. HDMI cable changed still no picture
You need to try some tests.
  • Does the same cable work with any other TVs
  • Do any other devices work on your existing TV ?
You also need to check that you have set the output of your device to HDMI and the input of the TV to HDMI. In the past the TV may have automatically selected HDMI when the device is turned on but sometimes that does not work.
Mar 23, 2014 | Iomega Computers & Internet
How to install sata harddisk
With Serial ATA technology quickly replaince IDE/ATA as the new standard in hard disks, more and more computer users will need to know how to install SATA hard drives. The process of installing a SATA hard drive is similar to installing an IDE hard drive, except a bit simpler. Follow the directions in this article to learn how to install a new SATA hard drive.
1.Detemine whether or not your hard drive supports SATA. SATA technology was not introduced into the market until after 2002, so any consumer PC before that will not support a SATA hard drive. To find out whether or not a SATA hard drive can be installed into your motherboard, you can review the manual that came with your computer, or you can contact your computer's manufacturer. If you have already purchased a SATA hard drive, but have your motherboard does not support SATA technology, you will not be able to use your new hard disk.
2.Power down your computer and remove any peripherals or connections. Ground yourself either by wearing an anti-static wrist strap, or by touching a piece of unpainted metal. Remove your computer's case.
3.Locate your hard drive bay. Your hard drive bay should be located beneath your CD/DVD drive.
4.Locate the SATA data cables on your motherboard. Review the image to the left to get an idea of how your SATA slots may look (not all motherboards look the same). The small, red connections on the bottom-left of the motherboard are your SATA connections.
5.Take your SATA data cables (the red, smaller cable pictured left) and plug the one end into the motherboard. Insert the data cable into the lowest numbered slot (i.e. 0, 1).
6.Next, you will want to locate your computer's power cable. Some computers will already have a SATA-compatible power cable available, but others may not. If your computer does not have a SATA-compatible power cable, you will need to buy an adapter. As in the picture above, it will have one white end and one black end. Plug the white end of the adapter into the white end of the power cable in your computer. It should look identical to the one in the picture.
7.Connect the data and power cables to the back of your hard drive. The larger cable goes in the larger slot, whereas the smaller cable goes in the smaller slot. If they do not fit at first, simply turn them around and try again.
8.Slide your hard drive into the drive bay. You will want to make sure that the part of your hard drive with the connections on the back is facing outwards. Then, taking a screwdriver, line up the holes in the bay with the holes in your hard drive and screw the SATA hard disk into place.
9.Power on the computer. If you have installed two SATA drives, unlike with IDE, you should not have to designate them as master or slave (both will be independent drives). If your computer is not reading your new hard drive, power down the computer and check all connections, making sure they are secure.
Sep 08, 2011 | Computers & Internet
My computer was in a fire and I wnat to try to recovery my pictures and save to a disk
This may be possible, but it obviously depends on rather or not your hard drive was damaged by heat, smoke, or water. If it's still in good shape you can purchase an external drive enclosure (online or at a big box electronics store I.E. BestBuy) which will allow you to hook your drive up to another PC via USB cable. From there you can browse your drive, select your pictures and other media, and then burn them to disk. You may also just choose to keep them on the drive - once it's in the enclosure it will be protected.
As far as the enclosures go - there are two types. Those for SATA drives, and those for IDE drives. The difference is the type of connector your drive has. If your unsure which you have, you should be able to take the drive into an electronics store so you can verify you get the correct part.
Finally, here's a link to one that's available online, just so you get an idea of what you should be looking for:
http://www.amazon.com/Rocketfish-Drive-Enclosure-Drives-RF-PHD35/dp/B00301EAP2
Best of Luck!!
May 04, 2011 | Dell Inspiron 531s Desktop Computer
I cant find my manual and I need to download my pictures from my computer
If your computer and external hard drive are connected via the USB cable, you can select your picture file, right click it and hit 'copy' then go into My Computer, find the External Hard Drive and right click it and select Paste.
Your pictures are now on the External Hard Drive.
Mar 03, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Have lost user manual so need assistance with downloading from camera to computer plus is their a specific USB cable as I ca't find that either.
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 11, 2010 | Fuji Cameras
Please send me manual of 250gb iomega portable
USB Desktop/External Hard Drive User's Manual: View Online [HTML] ' Download [295KB zipped HTML]
Quick Start Guide [PDF 564KB]
May 06, 2010 | Iomega 33089 250 GB Hard Drive
Want to remove wd2500 drive from HDD enclosure and
OK your hard drive is an ATA drive.
You motherboard will have two hard disk controllers, on the 1st controller the ATA cable will have two connectors - a connector will have the C drive hard disk attached to it and the jumper on the hard drive will be set as the Master drive. You may also have a CD or DVD drive connected to this cable, if so then the CD or DVD drive will be jumpered as a Slave drive.
If the second connector does not have a drive connected, then you can connect the second hard drive to this connector BUT it needs to be jumpered as a Slave drive.
You may elect to connect the second hard drive to the second IDE controller instead on the first controller. If there aren't any drives on the second ATA cable then the second hard drive can be jumpered as either a Master or Slave drive.
If there is a drive on the second ATA cable you need to determine the jumper setting of that drive and then set the jumper on the second hard drive to a different setting. BOTH drives on the same cable CANNOT have the same drive setting.
After installing the second hard drive, check the BIOS configuration of the second hard drive, if the hard drive is detected then when Windows boots up you will see the hard drive and its contents.
Dec 08, 2009 | Western Digital Caviar WD2500BB 250 GB...
Sata hard disk drive on asus p4v8x-x motherboard
I have checked and you computer does use SATA drives. If you don't have a manual, send me your email and I will forward the manual @ no cost. The manual will show you where to insert the cables.
Jan 20, 2009 | Computers & Internet
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
IBM NetVista PC Desktop Logo
174 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
