Question about Whiptail Interactive Gangland for Windows
I cant install the Patches for gangland
I cant install the Gangland patches, i tried them all and they say the same thing: some or all files could not be patched, please reinstall then run this patch again and ensure that you have 400/250MB of free space on the hard drive where Gangland is installed. I'm low on space but not that low, i have at least 60GB left on my hard drive!!!
The game works fine, but these damn patches wont work, what i did is,
1:Installed the game
2:Reboot
3:play a minute or 2
4:tried to install the patches
5:they all failed
it's long time since the last post here, anyway I have a problem with this game's patch,
I want to install latest patch which is 1.4
it's said for installing that, these versions are needed :
1.0.2 , 1.0.3 , 1.1.0 , 1.2.1 , 1.2.2 , 1.3.0
I have downloaded and installed 1.1 and 1.2.1
but couldn't install 1.3
seems 1.2.2 is needed, but couldn't find it anywhere, can anyone
Posted on Dec 05, 2012
  • Emir Dec 05, 2012
2 Suggested Answers
  • 140 Answers
SOURCE: how to use gangland cheat codes
check the version you have installed, the cheat sites says you need at least 1.1 version to make cheats works. if you have 1.1 or higher, just press ~ button to open console window, there you can type the cheat codes.
Posted on Jun 02, 2010
How do I install patches?
Download n install 2 softwares for G2 from ZOOM website.
1. USB subsystem. Driver to connect zoom fx to PC/Notebook.
2. EDIT & SHARE. Software to create/copy sound patch.
Connect USB cable from G2 to PC/notebook.
No need adapter power supply, because the power is supply via
USB cable from PC/notebook.
Open EDIT & SHARE. It's easy,like copy,paste,rename,delete etc.
Just open the menu that you want to do and follow the
instructions. Sound patch can be load from files that you
download, or create it in EDIT & SHARE.
Patch can be load one files or group. Right Click the sound that you want to change,copy-paste it from new file/sound.
You can import/export files/patches from/to PC library (downloaded files).
It is recomended that you save/backup your original files,before load new sound.
I hope this helps.
Regards.
Aug 31, 2015 | Zoom G2 MultiEffects Guitar Pedal
Tip
First Choice on doing anything on the Wii
The most important thing right away after you install homebrew is to install bootmii or preloader, as they both protect your wii from getting bricked.
if you are trying to install any ios or cios or even themes , its pure suicide to do it without both programs as those installations will eventually brick your wii.
these are the advantages of preloader and bootmii , (prefered choice is bootmii).
1-Boot mii: BootMii is a piece of software that can be installed as an IOS or inserted into the boot process. As an IOS, it provides a fast way to back up your Wii's internal NAND flash memory, and will eventually form the basis of a new generation of homebrew applications for the Wii. Inserted into the boot process, BootMii provides you with a "safety net" -- you can back up your entire Wii to SD in under three minutes! If you were to brick your Wii, BootMii would still run and let you restore your backup from SD, quickly and painlessly. BootMii also allows you to directly boot The Homebrew Channel or other homebrew from SD, bypassing the "warning screen" and the rest of the menu.
2-Preloader: Preloader is a small application which places itself before the System Menu. Its main feature is to directly boot the Homebrew Channel or a file you can install from a FAT device. Preloader is also able to apply memory patches the system menu to remove limitations or other things. Since Preloader places itself before the System Menu any problems that would cause the System Menu to fail are not causing your whole Wii to stop working.
If autoboot is enabled and you want to access Preloader's menu simply hold RESET while powering the Wii on
also
Preloader offers hacks as: install additional System Menu patches, simply copy the "hacks.ini" file included with preloader into the root of your SD card. (Ensure you are using the correct hacks.ini for your Wii's region.) Then, boot into Preloader's settings, and chose to enable or disable the patches in the Hack Settings menu.
Once applied, your patches are placed in NAND, so feel free to erase the file on your SD card.
The format for adding additional hacks, or patches, to your hacks.ini file is simple and should explain itself.
on Apr 23, 2010 | Video Game Consoles & Games
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
Running Installing 3 patches over 10 hours
I assume when you say "Patches" you are refering to windows updates, a.k.a., patches, on patch tuesday? Shut the computer down, reboot. Open windows updates, run.
Nov 18, 2012 | Sony Computers & Internet
What are some gangland cheat codes for pc . i cant find any. please give the codes not just a link to the site as i cant access most sites
Normal.dotm 0 0 1 135 771 Statens bygningstekniske etat 6 1 946 12.0 0 false 21 18 pkt 18 pkt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Vanlig tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin;} Hello juz10smith
Press ~ during the game to access the console, then enter the following (Version 1.1 or higher required):
cheat loonies - Crazy guy who can hold two tommy guns
cheat alienprophets - Fake cops
cheat irissuxx - Yeah! message
cheat iwillmakethefamilyrich - One lawyer
cheat iwillripyouramsoff - One enforcer
cheat youlittlehottieyou - One seductress
cheat pocketsfullofdough - One businessman
cheat yourliverlandedoverthere - One bazooka guy
cheat youhadbetterwearkevlar - One black widow
cheat trustmewithyourlife - One bodyguard
cheat ihavetenpoundfists - One super bouncer
cheat likeatonofbricks - One bomber
cheat youwillbestunned - One assasin
cheat whatwasbrieflyyoursisnowmine - One thief
cheat iwilltakecareofyou - One big momma
cheat thegreatvassilizaitsev - One sniper
cheat iknowodintoo - One ninja
cheat kidiseeeverything - No fog of war
cheat wowitsgreattobetheboss - God mode
cheat needmorelead - 1000 everything
cheat youbetterpay - 100,000 cash
Hope this helps. Good luck!
ajblaj
Sep 13, 2010 | Video Game Consoles & Games
How to use gangland cheat codes
Jun 02, 2010 | Whiptail Interactive Gangland for Windows
How do you active a patch for a game once you download it? It is an unofficial patch
This depends on the game and who made the patch.
MOST patches have what is called a self extracting installation file.
Assuming this is a windows machine.
It should have an .EXE extension. Double clicking this will cause the file to execute and install. Be careful however. Unofficial patch Screams VIRUS!!! Also keep in mind running patches will cause anyone with a different version number to be unable to connect with you in a multi-player game.
Use caution and certain of who and where this patch came from.
Oct 03, 2009 | Jade Empire Special Edition for PC
Quicken 2004 Installing on Windows Vista
Jan 18, 2008 | Intuit Quicken Basic 2004 (028287007543)...
My company of heroes patch wont work
hi i cant get the company of heroes path done i did it 3 time if you get this pleace help me!!!!!!!!!!!!!!!!!!!!!!!
Sep 28, 2007 | Computers & Internet
Open Questions:
See all Whiptail Interactive Gangland for Windows Questions
Whiptail Interactive Gangland for Windows Logo
778 people viewed this question
Top Whiptail Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Whiptail Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
