Question about Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER -
Drain tube for leaf trapper is not working water is not fllowing through it to bring debris from bottom of pool debris is not be sucked into drain in bottom of pool
Call T.R. of the wayne county R's he can fix anything ! LOL run Forest run
Posted on May 29, 2010
Water leak in drivers footwell on mitsubishi carisma
you have a cracked heater core. Those are very difficult to change. Take your car to a professional garage
Dec 22, 2012 | Mitsubishi Montero Sport Cars & Trucks
Kreepy is making lots of movement noise and is sucking on to pool bottom but not moving
Ensure that the main drain and all suction lines are closed, except for the suction line to which you automatic pool cleaner is attached. Check for debris in the filter or pump basket and the flapper. Flapper debris could be causing a loss of seal to the pool floor.
Feb 21, 2011 | Universal Kreepy Krauly In-Ground Pool...
My creepy sucks for a while and then stops
There are several things that you need to check if these pool cleaners stop working or lose suction. Check for debris or obstructions in the flapper. If you have something making your flapper lose its seal or prevent flapper movement, your water flow can be restricted. Make sure that you filter and pump are not becoming clogged with debris. Make sure that the main drain and all suction lines are closed except for the line you are using to run the pool cleaner.
Oct 12, 2010 | Universal Kreepy Krauly In-Ground Pool...
Water pooling in the fridge.
excess water usuall y means there is a blocked drain tube in the bottom of the fridge.this can be cleared by using a small bottle type brush and run down through the drai hole to clear it.also check the drain tube from the rear of the fridge and make sure there is no obstruction near the drain pan
Feb 24, 2010 | Refrigerators
Ice pooling in bottom of frostfree freezer
Sounds like the drain tube(s) which carry the defrost water from the freezer and refrigerator to a catch pan at the bottom of the refrigerator are stopped up.
I have seen these drainage tubes stopped up with debris which prevented the water from draining out. This defrost water can be turned into ice which blocks the defrost drainage even more so.
Oct 09, 2009 | Refrigerators
Pump is not pulling the water from the pool
*Check all of the drain plugs*...You would want to check for air leaks on the suction side of the pump. Make sure that there is water at least 3/4 of the way up in the pump and the valves are in the right position (sometimes turning the skimmer off and just sucking from the main drain can help). Also check to make sure that there is water in the skimmer, and it is not getting sucked dry. Next lubricate the pump lid gasket, and try some silicone around the threaded pipe on the front of the pump. If all this fails you could have some debris stuck in the impeller.
Apr 05, 2009 | Pentair Superflo 2 HP In Ground Pool Pump
Water leaking in to car from clogged drain tube
the a/c drain tube is ONLY to drain a/c condensate coming of the evaporator in your a/c system. Has nothing to do with rain, but everything to do with high humidity. If you put you a/c in "ecirc" mode when using the a/c, you cut down on condensate draining by about 70%.
WItht he a/c running ona humid day, you should see condensate draining out of the drain tube on the passenger side under the car body.
The rain water is another story. You have an air intake we call a "Rainhat" that is under the leaf screen at the base of the windshield towards the passenger side. If you have rain water dripping or running into the rainhat, it will run into your heater plenum (the big, black plastic thing under the instrument panel).
Remove the leaf screen and look for leaves or other debris clogging the area around the rainhat. look to see if water is running along the metal trim above the rainhat and dripping into the rainaht opening.
I once fabricated a cover over the rainhat using the bottom of a plastic anitfreeze bottle. I made an opening at the rear so it could still draw air in without restriction. It solved the water running along the base of the leaf screen and drooping right inot the rainhat. It rusted the blower motor and ruined it.
Good luck.
Feb 17, 2009 | 2001 Volkswagen Jetta TDI
Water coming into drivers footwell
windscreen surround has rotted away or drain holes under wiper motor facia blocked,the area above the firewall where the wiper motor sits covered with a plastic trim/cover
Nov 13, 2008 | 2004 Volkswagen Golf
Draining extra water
Cut off the zip tie that holds the drain tube. Bring the drain tube as close to the ground as possible and siphon out the water - yes, that means sucking on that hose. Have a bowl handy to collect the water, or do it somewhere you don't mind getting wet. Just keep the end of the hose lower than the basin of water and you should have no problems.
Oct 10, 2008 | Haier HLP21E Top Load Washer
Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER - Logo
128 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
