Question about Clarion AX423R Cassette Player
Radio does not keep the tuning when turned off anf back on again- does it have a battery back up for the memory?
    President:
  • 676 Answers
Check to see where the yellow wire of the radio is connected to. It should be connected to a source that has a constant +12 volts. Good luck.
Posted on May 28, 2010
How do I set the clock on my 2009 impala super sport
Click the clock button to the left of the cd slot and then turn the tuning knob to move it forward or back- then click the clock button again to do the minutes and move with tuning knob, then click clock button again to select either 12hour or 24 hour (military time- example 7pm=1900 hrs). the buttons with numbers on them are to save presets on the radio of your favorite stations- just push and hold the number you want it on after you have tuned it in with the tuning knob until it beeps and then it will be in the memory.
Nov 18, 2016 | Cars & Trucks
How to keep radio stations tuned in when radio turned of
If your radio has memory locations where it stores station frequencies then you can store those frequencies for easy recall. But if your radio does not have memory storage then it will usually tune in to the last station every time you turn the radio on.
Sep 14, 2013 | Audio Players & Recorders
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
Feb 17, 2011 | Teac EX-CD3 CD Shelf System
My Radioshack Pro-82 Scanner is stuck. I turned it on, held down the "lock" button until the keypad locked. The screen didn't display the "locked" symbol, but I can't use the keypad either. Even if I try...
First reset the scanner. This will not remove frequencies from memory. Turn the scanner off and then on again. Use a straightened our paper clip to gently push the "Reset" button on the side of the case (small hole). If that doesn't work, the next thing to do is to reinitilize the radio. This blows everything away so its the last resort. If you have the cable adapter and CD ROM for the radio, you may still be able to back up the scanner and reload after you do this. If not, be prepared to reprogram.
Turn the radio off and back on again. Hold down the "Tune/Clear button and again push the reset button. The display should clear. When the display returns, release the "Tune/Clear button
Now reprogram.
Aug 16, 2010 | Radio Shack Pro-82 Scanner
I can tune in the radio but when i switch of the ignition and switch back on all the stations are lost cheers
The wires are backwards. The Yellow wire is to be for direct power to battery so it keeps memory. The red power wire is to turn on when igniton is turned on.
Jul 09, 2009 | Clarion DB238R CD Player
Preset stations
This is how to preset stations on a P2257 Koss:
Tune to desired station.
Press and hold in the Memory button for a few seconds, then release (the Memory readout should be flashing on the display).
Press the Memory UP or DOWN button until you have the desired 1 through 10 designation for the station, then release.
Go back to the Memory button, press again and release.
Aug 20, 2008 | Koss PP257 AM/FM Radio
Setting the stations on memory
OK HERE'S WHAT YOU DO
1. USING THE UP AND DOWN TUNING, TUNE IN THE STATION
2. PRESS THE MEM SWITCH (LEFT SIDE OF ROUND SWITCH)
3. PRESS STATION LOCATION
4. PRESS MEM AGAIN ---- THAT'S IT
SUMMARY: TUNE, MEM, SET STATION, MEM
Jan 01, 2008 | GPX RDT4004SP AM/FM Radio
Tuning the radio
You have two "hot" wires going to the radio. One is the main B+ power and the other is for the "mem" function which keeps clock time and radio station presets in memory. Make sure that you have 12 volts to the memory wire (blown fuse?) If you do then you may have a problem that requires a trip to your local repair guy. Do you loose your preset stations when you turn off your car and leave the face in place (wait several minutes before turning car ignition back on)? If that is so, then you most likley don't have B+ to your memory wire. Good luck.
Aug 16, 2007 | Sony CDX-L480X CD Player
Clarion AX423R Cassette Player Logo
66 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
