Question about Dell PowerEdge 2600 Server
Dell poweredge 2600 no me permite formatear marca un error me dice que inserte un disquette en la unidad a pero esta iniciando desde cd que puedo hacer o que necesita mi servidor
5 Suggested Answers
nblady
  • 206 Answers
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Posted on Feb 24, 2010
Mikenet2620
  • 106 Answers
SOURCE: No puedo instalar Small Business
Si el sistema operativo no reconoce tus disco, y ya has creado un arreglo nivel 1 o 5 y en la bios si puedes ver los dicos, el problema es posiblemente que necesites cargar los drivers de la controladora. Si puedes ver el modelo de la controladora (visible en el post) dirigete a la pagina de hp.com/support escoje el pais USA para que tengas acceso a todos los drivers, descargate el ultimo driver de tu controladora y cuando este instalando windows presiona f6 para cargar los drivers
Posted on Aug 30, 2010
puertobori
  • 7733 Answers
SOURCE: buenas noches, apenas enciendo mi
Use a floppy disk or USB memory key to create a password reset disk using the following Microsoft instructions: How to Create a Password Reset Disk
The easiest way to recover from a lost password situation is to use a password reset diskextlink.gif. If you have a reset disk, follow these steps:
  1. At the Windows logon screen, click Reset password.
  2. Insert the recovery diskette or USB key.
  3. Follow the instructions on-screen to create a new password.
  4. Log onto the account using your new password.
new_note.jpg Note: Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
Issue 3: Resolve Error: The User Profile Service Failed the Logon
The following Microsoft Knowledge Base Article provides instructions on how to resolve The User Profile Service Failed the Logon. User profile cannot be loaded error.
"Error message when you log on to a Windows Vista-based computer by using a temporary profile: "The User Profile Service failed the logon. User profile cannot be loaded"extlink.gif Article ID: 947215.
Issue 4: If You do not have a Password Reset Disk
If you have lost or forgotten your password, and a password reset disk is not available, reinstalling the operating system is the only recourse. For information on reinstalling Windows, refer to Dell Knowledge Base Article, How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Posted on Nov 07, 2010
josema_sv
  • 500 Answers
SOURCE: mi servidor power edge 2600
Hola, efectivamente hay una falla del ventilador, el LED naranja lo confirma, lo mas probable es que sea necesario reemplazarlo.
Posted on Mar 02, 2011
DRIVER POLAROID PDR 300
Hola a todos, el grabador tiene los controles en dos circulos debajo de la pantalla, en el de la izquierda, con el grabador ENCENDIDO, debes oprimir unos segundos el boton rojo del centro que dice ERASE, y aparecera la leyenda DELETE ALL titilando 3 veces, y luego dice FORMAT, tambien titilando. En este momento oprimimos nuevamente el boton ERASE y el grabador comienza a formatearse, en la pantalla aparece el mensaje WAIT, por lo que esperamos a que termine el proceso, y LISTO!!!, cuando lo vuelvas a conectar a la PC te reconocera las 4 carpetas. Tambien yo lo formatee con la PC y estuve varios dias con este problema. Pasa que luego de un tiempo de uso, y aunque vayas borrando las grabaciones que hagas, la memoria se ocupa totalmente y te pide el formateo. Espero que te haya servido. Saludos desde Buenos Aires
Sep 20, 2012 | Polaroid PDR302 Digital Voice Recorder
Hola midvd no lee los discos el laser si funciona pero en la pantalla me dice que no hay disco a donde lo puedo llevar para que lo reparen?
Hola
Su unidad de lector l?ser tiene problemas. Sustituci?n de que es un trabajo especializado, y debe ser realizado por alg?n t?cnico de servicio con experiencia. No ha dado ning?n n?mero de modelo de la marca de su dispositivo. De todos modos, es repararlo por su centro de servicio autorizado, por cualquier technican de servicio con experiencia. Aceptar.
Jun 14, 2011 | Durabrand PDV-709
Hola, resulta que estoy intentanto instalar un nuevo sistema operativo en la dell power edge 1800, pero no he podido porque la dell no arranca desde el cd. Entre en la bios y en la secuencia de booteo no...
Install another cd unit that is recognized by bios so you can install the software. Without that you can do nada!
If another known good player is used and it also is not recognized then you have an issue with your CMOS - not a good thing!!!!!!!!!!!!!!!
Sep 09, 2017 | Dell PowerEdge 1800 Server
Hola no puedo entrar a mi face me dice q esta temporalmente suspendido q inicie desde faceboornk
Hola soy ulises avalos monroy no puedo entrar a mi facebook me dicen que esta temporalmente suspendido que inicie desde un ordenador de www.faceboornk.com
Mar 07, 2011 | Facebook Social Network
HOLA SOY SANDRA, TENGO PROBLEMAS CON MI REFRIGERADOR WHIRPOOL WRT 18AEC EL CONGELADOR NO SE APAGA ESTA PRENDIDO DESDE AYER, Y NO ENCUENTRO EL MANUAL. ME PUEDEN AYUDAR . MUCHAS GRACIAS
Hi!! Primero asegurate que el control de la temperatura del congelador este aproximadamente en el numero 3. Cuando dices que el congelador no se apaga, quieres decir que el ventilador del congelador esta prendido siempre, correcto? Si el ventilador esta prendido, el compressor y el ventilador que estan abajo, detras del refri tambien deben de estar prendidos chequea por favor. Si esto es correcto, desconnecta el refrigerador por unos 20 min. y luego lo connectas de nuevo, esto hara que el timer se haga reset, si ese es el caso, el problema se solucionara. Si no me envias un comentario y tratamos algo mas. Estuve buscando un manual para tu unidad pero no he encontrado ninguno en espanol, voy a seguir buscando.
Si le haces click en este link, te va a llevar a donde esta un diagrama de las partes the tu unidad, si tenemos que tratar algo mas, te va a ser util para saber cuales son las partes y sus nombres y me puedas entender mejor. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Parts%20List%20(SP)%20-%20WRT18AECLM00.pdf
Avisame lo que pase por favor.
Jan 11, 2011 | Refrigerators
Como puedo instalar los drivers de la camara web. Cuando conecto la webcam, la pc me PIDE que Inserte el CD pero me dice que no encuentra los archivos . Puedo descargarlos de algun lado? es una GE 98650,...
ok necesitas bajar el driver directo desde la pagina GE 98650 y si es posible el software que viene con ella si es que perdistes el disco. Verifica si a camara es compatible con tu sistema operativo.. o si ya salio un update para ella que resuelva el problema.. Todo se resolvera bajando thel propio site de la camara las ultimas drivers y actualizaciones... Por favor dale a click que mi informacion te ayudo suerte o me avisas para darte otros pasos
Dec 28, 2009 | GE EasyCam Webcam
Ibm 06p2525 alguien podra decirme como configurarla para que inicie desde el CD de instalaciã³n de XP pues en el bios, no viene opciones de arranque. Y ya probe con F1 hasta la F12 y ninguna me...
El disco de instalación y su programa que usa (¿windows XP home?) son muy diferentes y lo que usted quiere hacer no va a darlo ningún beneficio. Déjalo todo como se fué diseñado. Aunque si podría hacer esto el resulto estaría una computadora muy lenta porque se va a tener partes que mueven. En muy poco tiempo necesitarái un disco duro nuevo y un drive de CD-DVD. Tiene una mente muy inteligente, pero deja estas cosas en vivo. Déjame que te doy una precaución. No juega con la tarjete madre, porque es una cosa muy delicada, sino que no estás preocupado pagar cómo US $ 300- 500 dólares y labor de mano de igual, porque quemastes la targata madre. No tengo más tiempo explicarlo pero mantenga sus dedos fuera de esta cosa tan delicada. Muchas gracias para la consideración y opción de nuestro servicio. Mi nombre es Constantino )arzconst es mi contraseña interna con Fixya.com=
Jun 13, 2009 | Computers & Internet
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
APARECEN EL ERROR 1010 Y NO PUEDO ENCONTRAR SOLUCION
XP or XP pro + service pack 2
1. put esta flash-stick on la PRIMARY USB porta no secondary
2. enable la usb porta adentro la bios
excellemente pronto asta
Jul 25, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dell PowerEdge 2600 Server Logo
214 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
