Question about HP Officejet 4215v All-in-One Printer
All of a sudden my hp photosmart c4750 won't copy, nor will it print in black from the pc. Ink levels are fine. It WILL print the test page with black on it. Hmmm
    Master:
  • 645 Answers
Try removing the printer drivers and reinstalling it.
Posted on May 29, 2010
It will not copy, and when I print, its very faint even at Best print quality.
You either have a faulty cartridge or the ink nozzles are clogged up. Follow the procedure for cleaning the print heads for your model.
Jan 29, 2016 | Office Equipment & Supplies
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
I need an owners manual for a HP Photosmart C4750
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3831745&
This URL contains both the User Guide and Reference guide for your printer. Once you select your language just download it.
Hope this helps
Feb 20, 2012 | HP Office Equipment & Supplies
HP C3150 is printing green instead of yellow. How do i get yellow?
You should first check your ink levels to make sure you have enough of all colors. Do this through the printer toolbox on your pc. If the ink levels are fine you should print out a diagnostic page. Follow these steps to print out a test page: 1. Press and hold the cancel button 2.Press the start copy color button. 3. Release both buttons.
If there were problems with the test page run the clean print cartridges utility. This can be found in the printer toolbox in the device services tab.
If that fails as well, you should look at replacing your ink cartridges with new ones.
Apr 22, 2011 | HP Photosmart C3150 Printer
How do i get the ink cartridge out?
Turn the printer on.
Lift the lid.
Look inside the lid -- some printers have "instructions" printed there.
Or, just wait 10 seconds, and the print-head will slide into position.
Push down on the ink-cartridge to "unlock" it from its socket.
Gently remove the ink-cartridge.
Oct 19, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Black ink will not print on Photosmart C6150; Ink
I'd do the reboot of the printer.Turn it off,unplug for 60 seconds,plug it back in,turn it back on and see if the black will work.After plugging back in it should clean the print head and then you can do a test page to make sure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00728224&cc=th&lc=en&dlc=en&product=1153494
This site will show you how to print a test page.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart C6180 will not print in black ink. Have all HP genuine cartridges, although I have used cheaper imitations in the past. Have tried aligning print heads, cleaning, master reset (# & 6...
do not print the printout from the pc.tyr to print a test copy by pressing the menu button on the printer and in that select the option print a self test.then press OK.if the test copy from printer gives proper black colour then its the print setting problem in the pc.just adjust that setting.but if the test page does not print any black line or object that means the cartridge is out of ink and needs replacement.
Nov 29, 2008 | HP Office Equipment & Supplies
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Officejet 4215v All-in-One Printer Logo
1,050 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
