Question about Refrigerators
I had an extra fridge outside during the spring and late winter. I live in the south (averge winter temp 65), so it worked fine. Now it is 90 so it stopped working. I made room for it inside two days ago, but it is still not cooling. Is this something that can be easily fixed? Or have I ruined teh fridge?
  • 1,284 Answers
Hi, there are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care
Posted on May 28, 2010
  • mlbritton1 May 28, 2010
    Maybe I worded my question the wrong way. Neither the fridge nor the freezer is working. Neith side is working.
  • Shehu Pro
    Shehu Pro May 28, 2010
    Hi, The problem is that the automatic defrost timer is not working, and as a result no cold air is blowing into the Fridge and freezer.
    Take care
Is it too late to prune my Knockout rose? Its over 5ft.tall. I live in South Louisiana.
Late winter or early spring is the recommended pruning time.
Jan 22, 2018 | Garden
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
Jan 18, 2017 | Refrigerators
I live in the northeast, can a mini pomegranate tree survive the winters?
The tree should have no problem surviving the winter as long as it is in a pot that you can bring in side. During the cold months, the tree should be brought in and put next to a window, preferably the sunniest one in your home. As soon as it starts to warm up, bring it outside. Mini pomagranates tend to blossom and produce fruit in late June/July/August.
Aug 05, 2013 | Garden
Frididaire fridge mod.#FRT21IL5DBA 4 1/2 yrs old. In outside storage room of carport. Stopped running after stretch of low 20's temps. in winter of 2009 Unplugged it, checked coils. Plugged it in when...
Well it should be fine when it warms up, these are not designed to run in anything below 60 degrees, when the temp gets too low it confuses the thermostat and it shuts everything off, as long as the room is above 60 should work fine.
Sean
Mar 30, 2011 | Frigidaire Refrigerators
I have an RP 2100 pool heater and the minimum temperature set point is 65 degrees. Every time the pool/spa temp falls below 65 degrees, the heater automatically turns on. How can I either disable this...
Do you have an electrical switch that turns this heater on/off?
Can the heater be unplugged?
Is the heater on a separate circuit breaker that can be shut off for the season?
Nov 27, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
It runs fine in the summer when temps are warm, but when it turns cold,especially when you first crank it up, it spits and sputters and will not run. It like its not get gas
PUT A SCANNER ON IT AND CHECK THE TEMP READING FOR THE COMPUTER IT IS MORE THAN LIKLY BAD LIKE IF ITS 40 OUTSIDE THE SENSOR IS READING 90 SO IT DOESNT GIVE IT THE EXTRA FUEL IT WOULD NEED WHEN COLD
Oct 15, 2010 | 2002 GMC Yukon XL
TV storage in sub zero temps
All electronics devices,can't be on exposer to cold 20 degrees or hot 110 degrees very long only a couples hours.Than the componnents on the pc board will malfunsctions or dies all together.Bring it with you and store it at 45-50 degrees should be no problems.
Apr 26, 2010 | Vizio VW22L 22 in. LCD HDTV
A/C air sometimes cold, sometimes not on VW Beetle 2001 Turbo
AC will not work with temps are cold even when it is turned on. The air is colder cause the temp is colder. The AC cycles in hot weather because the AC charge is low and needs recharging. You will know this if you open the hood run the AC and you will hear the clicking sound of the AC compressor magnetic clutch. You can recharge it easily buy buying a compatible can of refrigerant. I suggest buying the kit with the gage so you don't overcharge the system which will cause freeze ups
Jul 03, 2009 | 2001 Volkswagen Beetle
Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Jan 26, 2009 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
