Question about HTC Touch Cell Phone (Unlocked) - Soft Black
Htc touch reset
How do you do a hard reset on an htc touch or device memory wipe?
  • HTC Master
  • 6,993 Answers
visit the link below, its very explanatory:
http://www.hardreset.eu/htc_touch_pro_hard_reset_soft_reset_en.html
Take care.
Posted on May 28, 2010
TouchFLO is not launching in my HTC touch viva phone
Not quite sure whether the actual system is corrupted but you may try to hard reset the phone. But note that hard reset will wipe all your data so take a backup before resetting it.
Feb 18, 2011 | HTC Touch Diamond Smartphone
Tip
HTC Touch Clear Storage Clear Storage Another way of clearing the device...
Clear Storage
Another way of clearing the device storage and reset all settings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first.
  1. Tap Start > Settings > System tab > Clear Storage.
  2. Enter “1234” then tap Yes.
I hope that helps.
________________________
Download the HTC Touch Manual.
HTC Touch Soft Reset.
HTC Touch Hard Reset.
on Apr 18, 2010 | HTC Touch Cellular Phone
Tip
HTC Touch Hard Reset Hard Reset You can also perform a hard reset (also known...
Hard Reset
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings - the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile® software and other pre-installed programs will remain.
To perform a hard reset
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:
3. Release the TALK and END buttons, and then press ENTER on
your device.
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
I hope that helps.
__________________________
HTC Touch Clear Storage.
I forgot the pass word on my HTC touch pro and have not backed it up yet. Is there anyway to get in without wiping the memory?
No, only way is to do the hard reset that will wipe it empty. anything you have on the storage card will be safe.
Oct 14, 2009 | HTC Touch Pro Smartphone
Tip
HTC Touch Soft Reset Soft Reset Occasionally, you may need to reset your...
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
HTC Touch PRO slide
try hard reset,if no joy then reflash ROM. Both will wipe device so do back up.
Aug 15, 2009 | HTC Touch Pro Smartphone
Htc diamond screen is locked and forgot code how can i unlock it
If you forget your password, you can hard reset or clear the device
memory. Before you do this, make sure you back up your data and files
so that you can restore them back to your device. For more information
about hard resetting the device and clearing the memory, see “Resetting
Your Device” in this chapter. See page 244
http://x.msmobiles.com/portal/images/htc/HTC-Touch-Diamond-User-Manual.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 23, 2009 | HTC Touch Diamond Smartphone
Htc touch diamiond keypad locked
u can unlock the key lock with long press of call end button like 4 sec see if ti works otherwise
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Mar 17, 2009 | HTC Touch Diamond Smartphone
Ho can do reset my htc touch p3450?
if u are talking about soft reset without wiping the data u just want to restart the PDA just press the standby power button up side for like 5 seconds it will switch it off then press again for the 5 seconds it will come on and boot and if u are taking about hard reset it will format all data take out ur memory card if u want to save it press the both call and end key together and then press the power button on the up side of PDA for like 5 seconds then screen will come up asking u to confirm just press the centre button of the 4 way joystick and go
Feb 19, 2009 | HTC Touch P3450 Smartphone
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
262 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
