Question about HP Photosmart 3210 Printer
Both hinges broke after opening the door. Are there any replacement hinges available? thank you,
  • 241 Answers
By checking with your local HP dealer you can either get used replacement parts or they can order a new part for your printer. They can also do an assessment to see what it will cost to replace the part. Sometimes it is cheaper to replace the printer than ordering new parts. You can also try your local rycle place and see if they have the same model that recently came in to be recycled.
Posted on May 28, 2010
E522B - About 6 mths ago, a the clip on the bottom hinge of the freezer door broke into two , depositing the one end on the kitchen floor . Fridge seemed to operate OK regardless. Today, the same clip on...
I know this thread is super-dead. Mine broke off a while ago and it means the door doesn't stop until it is 180 degrees open. The bit that broke off is the door-stop part of the lower hinge.
I just put this here in case it helps someone else stumbling upon this thread as I did.
As far as I can tell, the part is available somewhere. I am off to find out where, next...
Aug 14, 2012 | Fisher and Paykel Active Smart E522B...
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My drivers side door drops every time I open my door. Is it because of the door hinge or do I need to replace the door pins?
the hinge pins rides on brass bushings. if the door does not latch replace the pin and bushings with oversized ones available at Chevrolet parts department
you will need a sring compressor which is available at Auto Zone
Feb 20, 2010 | 1990 Chevrolet S-10 Blazer
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
GR556LRKS How do you disassemble the door to replace the hinges?
If your Whirlpool is anything like my Kenmore,you just open the door to the first stop,(open about 6")and just pull up.If your door has a glass front,be very careful where you set it.I broke my glass.I was playing with the hinge.
Dec 08, 2009 | Whirlpool GR556LRKS Electric Kitchen Range
Popping sound from the doors when open and close
door cam broke off or got left off durring reassembly usually black plastic 2 parts 1 on door 1 on hinge some models require replacing the hole hinge put some silcone based lube on new ones
Jul 01, 2009 | Kenmore Refrigerators
The piece that connects the vertical hinge to the door is broken.
Try partsdirect.com they have one of the best parts resources available. you will need your complete model number off of the inside of the unit it is located either on the eiling or right hand wall of the refrig section. thx Peyton
Mar 16, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Bolts broke on bottom drivers door hinge
a vw wreckers or dealer will sell you the correct hinge bolts with the year model on you
Nov 08, 2008 | 1998 Volkswagen Beetle
HP Photosmart 3210 Printer Logo
252 people viewed this question
Seeker5211
Seeker5211
