Question about Epson Stylus Photo R1900 InkJet Printer
Communication Error The printer is connected via USB and is recognized by my Mac, but during printing I get a "communications error." I have changed the cables and plugged it into different ports with no success. I have also uninstalled and reinstalled the software with no effect.
  • 1 more comment
  • kyle_ads May 29, 2010
    installed the driver, but with same results.
    Still did not have success. I am running 10.6.3 with printer driver 6.62. I can use the printer utilities, but cannot print from any applications.
  • kyle_ads Jun 01, 2010
    I ended up deleting all the previous versions of epson printer drivers, and used disk utilities to repair permissions. I restarted the computer and updated the drivers via software update. I turned on the printer and added it via the print/fax system preference panel. I worked as it did before I updated to 10.6.3.
    Thanks to all who helped.
  • 428 Answers
  • 1 more comment
  • Tharinda
    Tharinda May 29, 2010
    Sad to hear that you still have the problem.
    Please check this link and it would solve the issue.
    Epson has created this thread to solve the exact issue.
    http://www.epson.co.uk/Store/Printers-an...
    This is the best resource that I could link you to since I do not know your Mac OS version.
    I got to know that while using fire wire it will not occur. Not the best solution though.
    One additional thing that you can do is to check the Console which is in the utility folder for errors.
    Finder > Applications > Utilities. From within the Utilities window, double click the Consoleicon.
    Check the log.
    You can contact me further.
    Thanks
  • Tharinda
    Tharinda May 30, 2010
    Well thats pretty weird. Many people still having problems with these two products.
    I think that you can use system utilities to print (from the mac) but applications are unable to communicate ?
    Have you checked the printing preferences?
    Have you tried the default print page size?
    Which applications were unable to print?
    Have you tried firewire?
    Is it the default printer? In the preferences.
    Is there a firewall/antivirus suite which might block ports? (or if you use any router or firewall to connect it the ports might have blocked - application wise)
    1. Delete all your Epson printers from the printer list.
    2. Uninstall the driver with the driver installer. If it's not available, go directly to point 3.
    3. Delete the content of the folder "Epson" under HD -> Library -> Printers.
    4. Search with Finder for your printer modell and delete all found items.
    5. Restart your Mac.
    6. Connect the printer directly to your Mac. If the printer could not be found connect it directly to USB and not to the FireWire or Ethernet port. Don't use an USB hub or the USB port on the keyboard.
    7. Load the current driver and install it.
    8. Go to the Printer Setup Utility and click on "add" you might want to choose "other printers") and choose the corresponding EPSON port. The printer will show up in the list. Choose it and - if possible - choose paper format "all". Click add.
    Then try once again
  • Tharinda
    Tharinda Jun 01, 2010
    Hi Kyle,
    It was a great pleasure to help you.
    Visit anytime and don't hesitate to contact us once again.
    Thanks for contacting Fixya.
    Reg.
    Lasitha
After years of using the same setup I get a communication error on my Epson r290.
Sounds like you have multiple drivers. On the MAC, go to the printer set up window in system preferences and select the r290, then go to the "-" minus icon at the bottom to dump the r290 from the list. Restart the computer with the r290 connected and see if the system recognizes it again in the preferences window. Hit the + icon to add it. Hope this helps.
Sep 04, 2014 | Epson Stylus R290 InkJet Printer
Why lexmark s305 on USB sometimes fails with communication error?
You may want to check the sites below for help with regards to your issue.
support lexmark com
May 16, 2014 | Office Equipment & Supplies
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Communication Error
yes may be try with diffrent cable and other usb port.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 06, 2010 | Dell 924 All-in-One InkJet Printer
Canon imageRUNNER C2058 Color Copier/Printer service manual have error e240-0000
E240 Error in communication of controller
0000 Error in communication data Check connector, check connection of sub PCB in the
controller box, check / replace DC controller PCB /
main controller PCB
0001 There is no response when 3 sec passed since the main controller had sent the pickup
request to DC controller during printing.
0002 There is no response when 4 sec passed since the main controller had sent the request
for image output to DC controller during printing.
0003 The engine is activated when jam occurs.
Jul 09, 2009 | Canon C2058 Color Copier
Communication problem with printer over Airport, i.e. won't print
try uninstalling & reinstaling the printer will only work...
Apr 25, 2009 | Office Equipment & Supplies
"Communication error"
HI-
How do you connect the printer to your imac? what type of cable are you using? if its a USB connection, then try going to system profiler and under hardware click on USB and on USB device tree you should have highspeed USB 2.0 and when you highlight that, it should give info for manufacturer as EPSON if thats the brand of the printer you are currently using. update me on this so that we can check if its really communicating with your imac-- thanks!
Jul 07, 2008 | Epson Stylus CX4200 All-In-One InkJet...
'communication error' and won't turn off
From my experience, FW and Epson printers don't always work well together.
Switch it to USB then delete and re-add the printer in the PRINTER SETUP UTILITY, and you should be okay
May 21, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer & PC not communication
Did you delete all printers before instaling drivers so that you would have a clean printer install .
delete all printers first from control panel via printers and other hardware. then reload printer drivers for this printer.
Jan 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Communication error
It would be helpful to know which operating system you have on your iMac. If you are running OS8.6 to OS9.2.2, then you may need to install drivers for the Mac to recognize your camera. If this is not the case, you may new a new connection cable. A work around for this would be to use a memory card reader instead of connecting the camera via a USB cable.
Dec 23, 2007 | Fuji FinePix S700 Digital Camera
Epson Stylus Photo R1900 InkJet Printer Logo
1,412 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
