Question about Maytag Neptune MAH5500B Front Load Washer
Washer does"nt do last spin
Hi , I have problems with my washer , it doesn't do last spin. I already used one of the solving problems from on line. The tip I used was to unplug the machine and plug back on again and took care of the problem for the time being. My question is do I have to checked something else or what I did would take care of the problem for good?
    Problem Solver:
  • 3 Answers
Often people think machine not performing "last spin cycle" when machine "pausing" allowing gravity to drain wet clothes then turn clothes again then pausing again allowing gravity to drain wet clothes. Wait for a minute or two verifying machine in normal "pause" status.
Posted on Apr 13, 2008
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Doesn't spin or agitate
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 26, 2011 | GE WBSR3140DW Top Load Washer
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Machine doesn’t spin,
heatman101
Oct 10, 2010 | GE WDSR2080D Top Load Washer
Washer doesn`t spin
heatman101
Oct 04, 2010 | GE Profile WPRE6100G Top Load Washer
Can a Pentair minimax NT that is fitted for natural gas be retrofitted for Propane use
Probally the easyest convertion on the market. Where your gas line comes in the heater the line loops up over and down. There are two unions on this at the base of the loop. take these apart and their is a washer in one and you replace it with the Propane washer and put back together.
Sep 01, 2010 | Pentair Minimax NT Heater
Maytag Neptune MAH5500B Front Load Washer Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
