Question about Garden
I have an Atco quiet shredder model 2000 which has stopped working. checked voltage to switch O.K but not sure how to proceed, it appears to have a capacitor between switch and motor, any advice on how to test and narrow down to a faulty part would be appreciated...
spurs21
  • 26 Answers
SOURCE: Drum Spins - NO HEAT (110.63942101)
Try replacing the heating element. This should solve your heating problem. Sign, Spurs21
Posted on Jun 12, 2007
SOURCE: craftsman compressor motor/capacitor problem?
I had the same tripped breaker problem with a similar Sears model 919.195060 (25 gal) and luckily I had access to another, almost identical sears compressor to swap parts to diagnosis it. It turned out to be the run capacitor, but from what I was finding in my on-line research, it could have been a bad winding on the motor or the start capacitor just as easily. If your resistor is outside of the capacitor, just cut the wire right at the capacitor and add flag termnals Mine had 3 wires coming out of the capacitor (not the normal terminal cap style), and two of them were basically just tied together (same color). I didn't have an external resistor. I bought a GE 97F9614 run capacitor (40 mf, 370vac) and other than having to cut out a bit of the plastic on the mounting bracket and buying "flag" style 1/4" terinals from radioshack, it fit and worked perfectly. It seems if GE is the only one that has the right dimensions (1.75dia x 3.88 long, not including the terminals. That capacitor cost $27.50 with tax at a local electric motor shop. Sears doesn't even have any info on the motor parts, like capacitor - they want to sell you a new motor for almost as much as a new whole compressor. I ended up looking at parts forr the motor on a Devilbliss (that's what the 919 means on the model number, that it's made by Devilbliss), but it was not an easy way to go and really didn't help that much). The easier/normal way of matching capacitors is to measure the case dimensions carefully and match up the voltage and uf (or mf) specs,
Posted on Dec 22, 2008
SOURCE: craftsman compressor motor/capactitor problem?
It sounds like either the check valve or the switch that lets the air pressure off of the pressure switch is broke. After the compressor pumps to shut off pressure, when it shuts off, it should let a short burst of air from the switch. If it does this, that parts good. Give it a little time, then manually push that plunger on the switch.( you're trying to see if the check valve, which is a one way valve, is leaking air back into the cylinder) If air is release from that plunger, the check valve is leaking and will not let the compressor start, because air has leaked back into the cylinder.
Posted on Mar 11, 2009
  • 4088 Answers
SOURCE: 1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Posted on Aug 23, 2009
SOURCE: fan stopped running. no power to the fan (ie, no
You may find the parts that you need at the following web site...http://www.eceilingfans.com/
They have all of the capacitors there. All you need are the number of wires and the capacitor micro-farad ratings.
Posted on Oct 22, 2010
Hello my name is paul and i am looking for a work shop manual for my atco 12/36 rideon lawntactor model 830 would you know where i can get one from please
Workshop manuals are usually only found at dealers. Try some of these links though.
  • ATCO - Official Site www.atco.com ... ATCO is a diversified global corporation delivering service excellence and innovative business solutions in Structures & Logistics (workforce housing, ...
  • Atco Product Support ' ManualsOnline.com www.manualsonline.com/support/atco My atco balmoral 17 rear roller jams when trying t. ... Service manual for atco balmoral 14s. ... manual Atco Commodore B17.
  • Atco Operating Manuals ' The Old Lawnmower Club www.oldlawnmowerclub.co.uk/makehelp/atco/opmanuals Atco Operating Manuals. View (active tab) What links here; ... Title ; atco1246.pdf: Atco 1246 : Atco 141720.pdf: Atco 141720 : Atco 172055.pdf: Atco 172055 ...
  • Atco Lawnmowers - The Finest Cut of All Atco Lawnmowers www.atco.co.uk Since our first lawnmower in the 1920s Atco has had an enviable reputation for the outstanding quality of our cylinder mowers. Save up to £100, from £899.
  • Operating Manuals ' The Old Lawnmower Club www.oldlawnmowerclub.co.uk/technical/opman/list The following operating manuals are available for free download from the site. ... Manual ; Atco 1246: atco1246.pdf: Atco 1755 and 2055: Atco 172055.pdf:
  • Old Lawnmowers and other Vintage Machinery www.oldlawnmowers.co.uk/ol-literature.php Old Lawnmowers and other Vintage Machinery. ... We have a range of Operation Manuals, ... Allen Motor Scythe Model 'T' , Early 1950s ; Villiers Atco 12" Hand Mower ...
  • Lawn Mower Manuals - How to Access Old Mower Manuals www.mowersdirect.com > How-To Library Shop by Brand [+] All Brands: Shop by ... However, finding a manual for a specific model can lead you on an Indiana Jones treasure hunt. ... Lawn Mower Manuals ...
  • Free Atco Lawn Mower User Manuals ' ManualsOnline.com lawnandgarden.manualsonline.com/manuals/mfg/atco/atco_lawn_mower... Find the user manual you need for your lawn and garden product and more at ManualsOnline ... Atco Lawn Mower Manuals. Showing Products 1 ...
  • http://www.bing.com/search?q=work+shop+manual+for+my+atco+model+830+&qs=n&form=QBRE&pq=work+shop+manual+for+my+atco+model+830+&sc=0-39&sp=-1&sk=&cvid=34EA8E0D9A52464A88BA2494B24AB80D
    Sep 14, 2016 | Garden
    The plastic over the on/off button broke, shredder does not turn on. Can this be replaced to work
    It appears that the controls are covered by a film with symbols printed on it; this shouldn't have disabled the machine and this type of control has no dangerous voltages present so safety is not an issue.
    This type of control generally uses small carbon buttons or a tiny enclosed switch assembly and neither of these are very durable and may not be making contact as they should.
    Another possibility is that an internal switch that is activated by the paper inserted may have failed.
    There does not seem to be a manufacturer named 'Universal' but the link below is a Chinese maker with a model very close to yours:
    View Product Details Shredder paper confetti cut paper shredder
    You seem to have no recourse other than contacting the firm that sold you the machine for service.
    Good luck=
    Feb 03, 2015 | Universal StripCut Shredder UNV48025
    Atco admiral 16 s
    open the remote control and clean the keypads contacts, from dirty+corroded+bad contacts, use contacts cleaner solvent.
    Use the digital camera or webcam cell, the LED must be TURN ON, otherwise proceed as indicated see the picture.
    Jul 14, 2013 | Televison & Video
    I HAVE POWER FROM THE SWITCH AND TO THE BOARD. HAVE 8.9 WHERE THE MOLEX LOOKING PLUG FEEDS THE MOTOR PROBABLY DC VOLTAGE NOT SURE BUT IT WILL NOT WORK. ANY IDEAS
    If you have AC voltage coming out of the switch to the pcb but the motor wont run then most likely the machine was jammed and left jammed....then the pcb fried...
    call Royal at 1-800-524-0799 for parts assiatance.
    Feb 10, 2010 | Royal 160MX Shredder
    240s4 KOBRA: Will switch on but wont swich to reverce or shred
    You have possibly lost the PCB inside the machine. If you are capable you can take the top cover off(Make sure its unplugged.) With a multimeter you can check the motor...normally black, red,blue wires.
    Black is common...should read about the same between black and red and black and blue. If you have a short cct in either direction the motor is faulty. Check the motor befor replacing the PCB. ...A bad motor will just blow a brand new PCB.
    you can contact www.kobrashredders@aol.com for parts.
    Apr 08, 2009 | Elcoman 240S4 Shredder
    No spark at plug
    Hi, I can see you posted this in April, so you may have sorted it by now!..? Is your problem that it will not start? If so and you have checked that the air filture and spark plug are OK, then you should make sure that all four lights are on, on the dash. Also you need to make sue that the black flap at the back directly behind the seat is pressed down properly. If it is up slightly it will stop it from starting as it is a safety feature. It has some sort of trip swith on it. I hope this has been helpful.
    Apr 05, 2009 | Briggs & Stratton Garden
    Bin light is staying on and we cannot shred any paper. The shredder does not appear to be jammed anymore. what can we do?
    check underneath to see if the bin full flap is working.
    First, uplug from power. Look underneath and see if you have a flap. If you do, then make sure it's quiet and move the flap back and forth. You should hear a microswitch click.
    If you don't have a flap and the hopper is removeable, make sure hopper is installed properly.
    Dec 18, 2008 | Fellowes SB-99Ci Shredder
    OM 99727 shredder not working
    I had this same problem. This is what I did to fix it.
    When I went to ShredCare.com (the recommended web site for technical support of this particular shredder), I read that 'Most models of shredders have a safety interlock switch that is activated by the basket.' Upon looking closely at my basket and the shredder, I found this safetly interlock switch and made sure to align it with the proper position within the basket. There is only ONE way to place the shredder on the basket and have this safety interlock switch activated. The switch is located on the underside of the shredder. Align this switch with the ridge on the inside of the basket. Listen carefully and you will hear the switch 'click' when in the right position. Mine is very touchy. I've even had to press in on the side of the basket while shredding to make sure that the ridge and the switch are making contact.
    Hope this helps!
    Aug 15, 2008 | OfficeMax 0M96431 Shredder
    Powershred 380-c
    Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
    Jun 16, 2008 | Fellowes Powershred 420 Shredder
    No Power!
    Check and make sure the paper catch bin is locked into place.
    IF the shredder doesn't see that the bin is in place, the shredder will appear dead for safetly reasons.
    There is a possibility that the control board was cracked but the only way to check that, is to take it apart and check.
    Good luck.
    Jan 06, 2008 | Tech Solution TS-4500 Shredder
    Garden Logo
    258 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
