Question about Tecumseh Enduro Vertical Engine 16 HP 1in x 3 532in Shaft Model OHV16204230F
Trouble hooking up throtle a choke
I just rebuilt a carburator on a craftsmen riding lawnmower with a 12 hp tecumseh motor. I can not figure out how to hook the throtle and choke arms up.
Farmall Super A, rebuilt carburator, cleaned tank and lines but will not run smoothly unless choke is pulled out at least 3/4. Any suggestions?
You have an obstruction in the main jet circuit of your carburetor. That is why you need to choke it - give it gas.
Nov 23, 2015 | Farmall Garden
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
I have a Honda 5 hp XR2600 presser washer, I have trouble keeping it running without the choke on. It starts right up, but it need the choke on to keep running.
I would try empting the gas out of the tank just to make sure you don't have some water in the gas. If that doesn't help you have a carburator that needs to be cleaned or maybe rebuilt.
Sep 30, 2013 | Garden
20 hp tecumseh, won't run unless choke all the way out and gas lever all the way up, also backfires. spark plugs good and seems to be getting plenty of fuel. Any ideas?
If the choke has to be on its not getting enough fuel into the engine. The carby and fuel lines etc have to be cleaned out. Regards Phil
Apr 12, 2011 | Tecumseh Garden
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
I have a 15hp tecumseh engine that will only run with the choke on.
You have a partially gummed up carburator. Get a bottle of carburator cleaner to add to your fuel. Follow those directions and you should be fine.
The alternate method may be to get a can of starter fluid. Spray the fluid into the air intake as the engine is running with the choke on. When the engine sounds better take it off of the choke status. Joe
Apr 11, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wiring diagram for 10 hp tecumseh motor.
no worries go to searsparts.com type in your model # and follow the prompts you can then print it out for free ?
Aug 27, 2009 | Garden
Riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Jun 23, 2009 | Craftsman Garden
Tecumseh Enduro Vertical Engine  16 HP 1in x 3 532in Shaft Model OHV16204230F Logo
114 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
