Question about Hayward 250kbtu Ng Pool Heater - Inground
Have a Pentair Trton Minimax Plus pool heater model 150. Replaced the Thermistor Probe. First night worked like a charm. However, now it will heat for about 15-30 minutes and shut itself down with all lights including red service light on. What can the problem be? Should I call a tech to come out or can I order part myself and fix it?
    Genius:
  • 1,417 Answers
the problem of your heater is from the element it is know as the heat provider it is most time in silver colour
the problem is not from the thermistor bass on the information you have pass across to me
what your heater need is replacement of a new element so that it can carry out it function again
this means that the old element in your pool heater is weak it need replacement
if you are sure that you can carry out this practical with out mistake then you order for the part and fix it up
Good luck and thanks for using fixya.
Posted on May 28, 2010
Why doesn't my Pentair Minimax NT heater fire?
Does it try to fire? Do you hear the blower kick on? If it only says E-- you might have a bad control input board. For it to fire the thermostat light, and pressure switch light must be lit up. Also you must push spa or pool mode on right...
Apr 29, 2015 | Pentair Pool & Spa
How do i get my pool heater to come on?
Open the service panel and look on the back of the board for 2 white or yellow wires that plug into it... disconnect it from the board, really wet your thumb with saliva, and touch the two connectors where you pulled the wires off of... and try to fire the heater... If it fires then you know that it is the thermistor.... I will show you a link to the thermistor on our site.... Do you have the minimax NT? if so here is your thermistor PENTAIR Thermistor probe complete 472101
Feb 14, 2015 | Pool & Spa
Error codes
You have a bad thermistor. The heater thinks that water temp is over 114 degrees.
Aug 14, 2013 | Pentair Minimax NT Heater
I have a Pentair Minimax NT 250k electronic heater. Turned the heater on today and it does not get through startup sequence. It flashes - - -, then flashes 888 (with red service light), then back to - -...
I would say the problem is the thermistor. The board will light up, the SW switch is green, but you get a display that flashes dashed lines and then what looks like 888. That is a start up code. The thermistor is located on the side where the water enters the heater. There are two screws at the top of the side panel. Undo the screws and lift the panel off. The thermistor is a probe with 2 small wires coming out and lead to the control panel. It is a very simple fix and is usually the problem if you have not experienced any other issues. The part runs between 30 and 45 dollars. Most pool stores would carry this.
thanks let me know if that fixed the problem
May 21, 2011 | Pentair Minimax NT Heater
I have a Pentair minimax 250k electronic. Opened pool today and when I turned power on to the heater, it won't get through startup sequence. Dashed lines flash, then 888 and service light comes on. ...
Most of the time I have found the problem to be the thermistor. It is located on the water manifold of the heater. Usually the panel lights, flashes then to 888 and back to dashed lines. SW light is green, and service light is red. It costs 25 to 45 dollars, and takes 5 minutes to repair. New thermistor looks identical to old so replacing it is very easy.
thanks please let me know if this was helpful
Err light on on pentair nt minimax. pushed power button, won't go off. any suggestions?
24 v at the transformer ? if yes unplug thesmostat probe if 888 change t probe if err change t board
Sep 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Hayward 250kbtu Ng Pool Heater - Inground Logo
49 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
