Question about GE JEM31 Microwave Oven
Where can I buy a replacement control board? - GE JEM31 Microwave Oven
  • GE Master
  • 19,396 Answers
Posted on May 28, 2010
  • tt869 May 29, 2010
    Thanks for the list that you sent me... the wb27x768 seems to be unavailable anywhere!!
    Where can I get a schematic, so that I can do a parts level repair on the circuit board!
    Thanks again, tom
  • Ginko
    Ginko May 29, 2010
    Hi.
    The original replacement for this part was WB27X0768. It went already out of stock and had been replaced by WB27X768.
    The part is not in stock anywhere.
    Try using Ge Spare Parts website:GE Parts and Accessories Store
    Contact this seller and see if the part is in stock.
    Also please give me the full model number. That will make easier for me to find out if a replacement.
WHAT is error 51 on a rational oven
Error 51 doesn't exist on SCC and SCC_WE models. If you are referring to a Combi-master or Combi-master Plus (CM or CMP) then error 51 means the battery on the control board is below 1.5 volts and should be replaced. Go to your local electronics or grocery store and buy a CR2032 battery, it looks like a quarter. Open up the front control panel and replace the battery.
Feb 26, 2013 | Microwave Ovens
My sharp carousel II microwave no longer heats food. Do I need to buy a new one?
The problem maybe the magnetron, or the inverter board if 7 years old or less, and possibly the keypad control board, by the time you add parts and labour cheaper to replace the microwave oven in the long run.
May 07, 2012 | Sharp Carousel R530EST Microwave Oven
GE Microwave # JESYO39WF001. Control panel locked up, beeps. Turned off and on. No help. Shows PF and other codes. Asks to enter code but key pad does not work. Help
Your the 2nd one today..bad main control board.. Cheaper to buy a new one
microwave unless you can find a replacement board and do it yourself... tell me what you want to do and I can walk you through..board is about $100 if you can find one.plus shipping repair shop would cost $200-225 incl. parts if they can get them
Oct 16, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Amana rfs12sw2a....1200watt The soft touch buttons don't respond except for number 6....
Sounds like a bad control board. First just check and make sure all of your connectors are in tight. Part numbers for the control board is 53001806 you could have a bad touch panel. rare and not typical but can happen part number for that is 53002019. I would probably buy both of those parts plug in the new panel into the existing control board and see of everything works. if so replace the touch panel and send the control board back. If it still does not work then swap the control board and send the touch panel back. hope that helps
Mar 19, 2011 | Amana RFS12MPS Microwave Oven
Where can i buy a control panel for a ge profile microwave model hvm1540
If you have pads failing on the membrane keypad or an "F3" error, you can buy the control panel assembly with a new keypad already attached here.
(You will need to enter your full model number from the tag in or on the unit, such as HVM1540WW001, etc.)
If you have other trouble, and it is the control board ("smart board") that is at fault, you can buy a new one here or you can get it repaired here for only $39.95 in most cases.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to fix
replace the touch key pad. it has failed.
If this is an integrated control design, you will need to replace the control board as well. some board designs link the control and key pad as one device.
Jun 19, 2009 | Panasonic NN-P794SF Microwave Oven
F9 error
Your Microwave uses "UltraWave technology"
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
The Magnetron sells for about $78.00 and is simple to replace. Check your owners manual for limited warranty on the MAG and electronic parts.
Jun 10, 2008 | Kenmore 62622 Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
I wiggled the ribbon cable between the control board and the intermediate circut board. The LCD came back for an instant. I am sure it is this ribbon cable. It looks like it is held on with adhesive. How can it be impossible to repair if people are offering to do it less than 40.00 dollars to fix it? Someone must be selling a replacement ribbon cable that will work.
Mar 20, 2006 | Sharp R-1501 Microwave Oven
GE JEM31 Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
