Question about Dell Dimension 2400 PC Desktop
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer, it works fine. I can't test anything on the computer as my monitor will not come on when connected to the computer.
    Scholar:
  • 47 Answers
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
Posted on May 28, 2010
Dell dimension 2400 keyboard and mouse and monitor not working
i think its a hardware issue so you should contact to dell care..
May 05, 2012 | Dell Dimension 2400 PC Desktop
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
I have an older Dell Dimension 2400 series. I have tried running the monitor with it. I will get it up and running only after numerous restarts. Most of the time when I start up my system the monitor...
If it's an older 2400 series and you suspect it doesn't have a good signal going to it, I would try the monitor on a different tower to see if it's the monitor. If it isn't, I would recommend that you try to disable and change the VGA card in the Dell, if possible to a known good VGA card.
Also, try wiggling the connections at the monitor and graphics card, if this applies.
Or else, it might be a lost cause for that tower.
Good luck on getting the Princeton monitor working with your Dell Dimension 2400 series.
Aug 17, 2010 | Princeton Digital VL2018W Monitor
What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Mar 03, 2010 | Computers & Internet
HOW IS THE WIRING SET UP IN MY DELL DEMENSION 2400 DESK TOP// I AM TRYING TO PUT BACK TOGETHER THE IINSIDE OF THE TOWER NOT SURE HOW IT IS SUPPOSE TO LOOK
Most of the connections only fit in one place ...
Here is the Service Manaul for the 2400 Dimension.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Jun 13, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 5150 Stuck In Pwer Safe Mode
Sounds like a problem with the video card. Cross check the connections to the CPU. If its all fine, Then Connect the monitor to a diffrenet pc and then use the monitors keys to change it to a plug and play mode.This might help with ur problem
Feb 01, 2009 | Dell Dimension 2400 PC Desktop
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
297 people viewed this question
Alun Cox
