Question about Brother MFC 7840W Printer
How do I enter the number "0" when entering a password for WLAN? I'm trying to connect to a WLAN using WPA encryption with a password including the number "0" but when pressing "0" it shows up as a star which is used to "hide" the password but it seems like it doesn't correspond to the number "0" as the password is wrong
    Problem Solver:
  • 15 Answers
Brother's documentation is non-intuitive. Pressing the ' 0 ' key shows a ' * ', but it actually is accepted as a 0 and moves to the next character entry position. Just take it on faith that it enters a 0 when it shows * when entering the wireless key.
Posted on Sep 30, 2011
  • 428 Answers
You can use shift keys Shift+1 as I remember. Check the network guide. Here Its a pdf. You have to have adobe reader as well.
Thanks for contacting Fixya. Please rate the answer if it helps you to solve the issue.
Posted on May 28, 2010
Wher to enter code
When I try to connect the Wireless network of my Intellinet router, Windows 7 displays the message below. However, there is no label with a pin code on the router.
[img src="http://kb.intellinet-network.com/images/Image/router/router_pin_code(2).jpg" alt="Type the 8-digit PIN from the router label" border="0" height="294" hspace="5" vspace="5" width="400">
Solution: Perform the following steps.
  1. Connect to the router with a network cable to one of the LAN ports
  2. Open the admin menu at http://192.168.2.1
  3. Login with admin / 1234.
  4. Click on GENERAL SETUP -> WIRELESS -> SECURITY SETTINGS
  5. Set "Encryption" to WPA Pre-Shard key
  6. Set the WPA UNICAST to WPA2 (AES) or WPA2 (Mixed)
  7. Set the pre-shard key format to passphrase.
  8. In the field Pre-Shared Key type in the password for the wireless network. It should be at least 8 characters in length. Write down this password. You will need to enter the password when you connect with your WLAN clients to the network.
  9. Click APPLY and APPLY again to restart the router.
  10. Wait for about two minutes, then re-scan your WLAN networks on your Windows 7 system and connect just like before. Now you need to type in the password you set up under step 8.
Oct 09, 2013 | Computers & Internet
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
I tried to change from WEP to WPA but the password will not go through. It makes it an unsecure line for wireless. What am I doing wrong?
The Short Answer:
Your password might not meet criteria. It also depends on whether you use a custom encryption key. If so, then you either need to create a 10-digit or 26-digit hexadecimal number (numbers 0-9 & letters a-f) depending on whether you use 64 or 128-bit encryption.
The Long Answer:
A WPA password must be between 8-63 characters long, and must only contain ASCII printable characters.
The 2Wire User Guide for the 2700 states the following:
"You can customize the following wireless settings in the Wireless Security panel.
1. From the Authentication pull-down menu, select an authentication setting: WEP-Open, WEP-Shared, or WPA-PSK.
Note: WPA-PSK authentication is supported only on HG model gateways.
Open authentication allows users to configure their wireless adapter as either Open or Shared; in either case an encryption key is required. Shared authentication allows users to configure their wireless adapter for Shared authentication, which requires an encryption key. WPA-PSK requires that users configure their wireless adapter using TKIP.
2. To use the encryption key that came with your gateway, click the Use default encryption key radio button.
To create a custom encryption key, click the Use custom encryption key radio button. If you select Use custom encryption key, you can define a 64-bit or 128-bit encryption key. For 64-bit encryption, enter a 10-digit hexadecimal number. For 128-bit encryption, enter a 26-digit hexadecimal number. A hexadecimal number uses the characters 0-9, a-f, or A-F.
3. Click SAVE"
May 04, 2011 | 2wire 2700HG-B Router (2700HGB)
How can i put a password for my router ? its Thomson TG585 v8
To setup security on the wireless router Thomson TG585 v8 please follow the below steps:
1.Open your web browser.
2 Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
3 If you have protected your Thomson Gateway with a user name and password, the Thomson Gateway
will prompt you to enter these. Enter your user name and password and click OK.
4 The Thomson Gateway GUI appears.
5 On the left menu, click Home Network.Under Wireless, click your access point.
Your access point is listed in the following format: "WLAN: ()". For
example, WLAN: Thomson83C7C7 (54Mbps).
6 The Wireless Access Point page appears.In the Navigation bar, click Configure.
7 Under Security, Select Use WPA-PSK Encryption.In the WPA-PSK Encryption Key box, type a the key of your choice. The key must be in one of the following formats:
a. 8 to 63 alphanumeric characters. For example: MyKey123 OR
b. 8 to 64 hexadecimal characters (characters from 0 to 9 and from A to F). For example: C54F48A5.
Click Apply.
8 Configure your wireless client(s) with the same settings.
Please revert back for any more issues that you may face.
Regards
Anand
Apr 27, 2011 | Computers & Internet
Trying to apply network key
You need your PC connected to the Router via cable, then open Internet Explorer.
In the Address bar type 192.160.100.1 and press enter, for login enter admin and for password enter motorola, now you should see a Motorola window with all the settings.
On the left side select Wireless, a different window will appear.
In the Security Mode field, select WPA and click Apply.
Skip the portion about WEP and go below.
Under WPA CONFIGURATION, for WPA Encryption choose TKIP and for WPA Authentication choose Local (WPA-PSK)
Under Local there is WPA Passphrase, here enter your desired password; try not to forget the password in the future or you have to repeat the steps above, also try to use a combination of letter and numbers.
Click on save changes and you have finish, now you can close explorer.
Please let me know if you need additional help.
regards
Mar 19, 2011 | Arris SURFboard SBG900 (49402201900) Modem
I have a belkin router + i need to know the wep password so i can install xbox live , please can you help ?
It is your personal ISP password. If you do not know what it is, you need to call your ISP provider with your account number in hand and ask for their help. We have no way of knowing what you used as a password, but they will be able to help you.
Good luck to you.
Dec 30, 2010 | Computers & Internet
My WAN is functioning, but my WLAN is not. I have reset both the modem and the router multiple times. What should I do?
Connect an Ethernet cable between the network-port on your computer and one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG/RENEW
Look for output like:
Default Gateway.....192.168.123.456
(Instead of '123.456', you'll get some other numbers!)
Start Internet Explorer.
Type http://192.168.123.456 (use your numbers!)
Login to the router (ID: admin, password: "blank")
Click to run the Wireless Networking Setup Wizard
Configure a SSID, an encryption-level (use 'WPA')
and a network-password.
Now, your WLAN will be ready to use.
Oct 01, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I had to put a wpa key on my pc for my belkin router so i could use it to play my ps3 online now i cant get my acer laptop to hook up to it?
You need to give more information to give specific advice, e.g. model of your laptop, WLAN adapter (if external), and operating system in use.
Some (very) old laptops do not support WPA or only a subset of encryption methods. Try to remove the WLAN from the list of known networks (Windows XP: properties of the WLAN adapter) and try to reconnect. If you are asked for the network passphrase, enter your WPA password.
Feb 07, 2010 | Belkin Computers & Internet
How do I enable wpa encryption? I have an
To set up the correct security protocols for your router:
1 Click Control Panel > Device Security.
2 In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive
characters as well as numbers. It cannot be longer than 64 bytes.
3 In the Login Password field, enter your Login Password. Create a password that
contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
4 Re-enter your Password.
5 Click Apply.
6 Once the settings have been accepted, click Restart and log back into the
Configuration Utility using your new User ID and Password.
7 Select Wireless > Basic.
8 Change the SSID to a user-friendly name and click Apply.
9 Navigate to Wireless > Security.
10 Select WPA-PSK from the ESS Authentication options.
11 Select TKIP from Encryption Status options.
12 Click Apply and then click Restart. Your wireless security configuration is now
complete.
Mar 26, 2009 | Arris WR850G Router (DHWR850G)
What is WEP and WPA encryption
WEP is like a clear connection with no encryption only to get this connection you need to enter key number and password.
WPA is more like encrypted connection and to that also you shall enter key number and password.
In today's wireliss connection speed there's no differences and you better use WEP since they got less connectivity problems
Nov 19, 2008 | Computers & Internet
Brother MFC 7840W Printer Logo
629 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
