Question about Casio Exilim EXZ75 Digital Camera
Please insert disk into drive E:
Why does my camera say this everytime i try to plug it into my computer and see my photos?
I looked for my disk, but i can't find it. >>
  • 1 more comment
  • lungsta May 13, 2008
    when i try to open my usb flash drive i get the same messaage
  • Anonymous Mar 12, 2009
    I am trying to put pictures from my camera to the computer but when I click on removable disk in my computer it says please insert a disk into drive E how do i fix this?
  • bla7 Apr 03, 2009
    this is the most shitty camera i have ever seen.
    Constant battery problems and now it does not show up as usb device when i connect it to my computer (running Windows XP)
  • 477 Answers
Goto www.casio.com/us for driver downloads.
Posted on Apr 16, 2008
SOURCE:
I am trying to upload pictures i took from my L200 Samsung camera by connecting the pc and the camera with a usb cable. But everytime i do that the camera suddenly goes off. I then look for it in '
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Jan 26, 2012 | Samsung L200 Digital Camera
Have disk in drive E but computer says "Please
try to put some cd lens cleaner if you have a previous cd cleaners you can use it
Aug 03, 2011 | Acer (KV.16X04.007) DVD Drive
Ive lost my disk and can no longer download my pictures to my pc?
if you have already installed the software from the disk onto your computer, you sholdn't need the disk to get photos from it to your pc. You might try this if you have a card reader on your computer. (if not buy a card reader, they plug into USB) take the SD card out of you camera (assumning you use a sd card) and insert it into the card reader, your comp should see it as a storage device and you'll be able to get your photos of the card much quicker than you ever could with the camera. also look for the software on your computer, it should be listed under Nikon.
Mar 19, 2011 | Nikon Coolpix S210 Digital Camera
How do you upload pictures using the cord? Is there a specific website you have to use? Everytime I insert the cord into my computer, nothing pops up. :\ Helpppp!
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 04, 2011 | Polaroid i1437 Digital Camera
I cant upload my pictures from the scan disk I use for my vivitar, my computer keeps telling me to insert the disk but the disk is already inserted??? What do I need to do?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 12, 2010 | Vivitar ViviCam 8025 Digital Camera
Everytime I try to connect my camera to the computer to share my photos it cuts off and want turn back on when I insert the cord and the camera cant share or less the camera is on soon as I take the card...
Jul 24, 2010 | Kodak EasyShare C142 Digital Camera
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
My computer won't recognize my camera when I try to load photos
Two Possibilities:
1) There's no driver installed, or the installation failed. ( A notification will say so when you plug it in ). Be shure the driver is setup properly.
2) The setting on the camera is set to "WebCam" and not "USB Disk"
In the settings menu, (Not the photo menu) on the camera there will be a USB Function option; this sets the camera up to behave like a cardreader and set the plugged in camera as an aditoional disk drive.
The other setting for the USB Function is "Web Cam" or "Digital Camera"; this will set the plugged in camera to behave as a USB Web Camera accessable to tv tuners or other recording or chat software.
To test, open the "My Computer" display of available hard drives, Disc Drives, Floppy Drives, and Memory Card Drives, then plug in the camera into the USB connector. A USB signal sound will alert you and a new drive should appear on the My Computer list, that's the camera.
If you don't get a new drive, then unplug the USB connector and enter the Menu on the camera, look for a USB function menu and set it to Disk drive, or whatever is not Web Cam function.
Note: This is for PC, and not Apple type computers, but I'm shure an Apple computer would be similar.
Cheers.
Richard.
Oct 13, 2009 | Canon Cameras
Keeps telling me to insert disk?
got a fujifilm xd card reader the icon is there on my computer everytime i click on it it tells me to insert disc
Jun 22, 2009 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
Casio Exilim EXZ75 Digital Camera Logo
553 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
