Question about Amcor A12000E Nanomax Portable Air Conditioner
Compressor Failing? HELP!!
I own an Amcor portable AC unit. When We turn it on the fan blows air, but the air coming out is not cold. Near the power light there is a light that reads COMP. The COMP light is on, so I am guessing the Compressor is blown. How do you fix it/ who can fix it, and what are the costs? Should we just buy a new AC Unit?
Thank you for your time and help!
I also have the same problem. I just bought a new model and the manual says that the compressor is on.
Posted on Jul 06, 2010
  • 420 Answers
Portables are priced to replace and not repair unless you are an HVAC tech with your own tools and supplies. There is no guarantee you could even get the imported parts. I recommend you replace the machine; make sure you check with local authorities regarding disposing of a used air conditioner that may contain refrigerant.
Posted on May 28, 2010
I have an AMCOR ALTL1200E, fan works, cold air comes out when the compressor turns on BUT after 5 minutes compresor turns OFF, then after 5 minutes again it turns on, what is wrong, thanks
Sounds like the unit is cycling off on a high head pressure (condenser coil too hot). When the condenser cools, the automatic switch resets. The unit cuts off again when the condenser heats up again. Clean the condenser coil, and clear out any debris (bird's nest, lint etc.)
Aug 30, 2013 | Amcor ALTL-12000E Portable Air Conditioner
I have a portable amcor ac-model-PLM13000E that is just blowing warm air-it is not draining any water.Thanks.
There is no water because the compressor is not coming on and circulating refrigerant. The water comes from the moisture laden warm air blowing across the cold evaporator. If the refrigerant is not flowing there will not be any water.
Aug 02, 2011 | Amcor Heating & Cooling
Unit comes on, lcd light not flashing, fan works, ac doesn't
If the compressor is running check the thermostat, check the possibility that the gas is present and has not leaked out.
If so the pumping must be checked of the compressor , the pressure switch also must be checked.
Jul 05, 2011 | Amcor PLM12000E Portable Air Conditioner
I've been running my portable ac unit for the past 3 years and now the unit just blows warm air...
Jun 29, 2011 | Amcor PLM-14000E Portable Air Conditioner
The unit will not produce cold air. It only pushes out room temp air. Altough I am not an expert, I think it is the compressor, or the tempature control unit (thermostat?) The unit does seem to make an...
I have a Amcor AF 1200E air conditioner, it only blows warm air and it is real dirty on inside filters, we took out 3 filters but there is still dirt on filters behind these, do we take it apart to clean, I would like a manual , do youknow where I can download one at? thanks
Sep 06, 2010 | Amcor AF9000E Portable Air Conditioner
No power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
Oct 25, 2009 | Amcor Heating & Cooling
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Amcor A12000E Nanomax Portable Air Conditioner Logo
986 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
