Question about King Of Fans HVS-205DTM
I need a 3 wing blade for a model FE 50 floor fan
I need a 3 wing blade for a King of fans model FE 50 floor fan
Artic king a/c model MWDUK12CRBCJ9 need a fan blade
Fixya does not sell replacement fan blades.
Sep 13, 2016 | Dryers
Need fan blade arm for Hamton Bay 52 inch Cameron II Plus Model 266028
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Aug 03, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Any idea where I can get replacement metal fan blades for a Patton floor fan?
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
Jun 08, 2010 | Patton U2-1487 Floor / Box Fan
Need fan blade for patton model u2-1887
it would be far cheaper and more easy to replace the entire unit
Apr 21, 2010 | Patton U2-1887HO Floor / Box Fan
I need a fan blade for a Aloha Breeze floor fan
check the big box stores for replacement blades.
Sep 28, 2009 | Dryers
I need to fine the ac fan model 1aca3001 serie
They amke a universal fan. Multi speed reverable. Just get a 1/3 hp and use that. I only carry 1/3 and 1/2 horsepower on my truck. I have been doing service work for 45 years. Rusty
Jun 06, 2009 | Weather King 10AJA2501AH Air Conditioner
Antigua Plus 56" blades brush light bowl & fan wobbles too much.
I learned that your Antigua Plus 56" Ceiling Fan was manufactured by King of Fans, a reputable company out of Florida that offers great customer support for their fans.
King of Fans website is: http://www.kingoffans.com
There are 3 FAQ's to read that can help you there about wobble, the proper size of the down-rod, and the fan hanging straight. Also the fan's description tells you what should be in the product's box. There should have been a balancing kit!
If you do not have your Owner's Guide, you can download it free! At any rate, carefully peruse it and follow the guide instructions, it seems that something has not been properly completed and or parts are missing. If parts are missing call customer service at 1-800-330-3267, and concisely describe the problem. I have found them to be wonderful at their customer service over the years.
Regarding the clearance between the bowl and blades, my first guess is that the blades may be installed either upside down, not pushed in fully, or pushed in too far. Regarding wobble, be sure to check page 9 of the Owner's Guide.
Best of luck! Your fan is gorgeous!
Pegi S.
Mar 08, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan blades
their is problem in push! change your fan push! then the wings are rotate
Jun 29, 2008 | Marvin 1210 Floor / Box Fan
Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
King Of Fans HVS-205DTM Logo
137 people viewed this question
Top King Of Fans Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a King Of Fans Kitchen Appliances - Other Expert? Answer questions, earn points and help others
