Question about APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System
Beeping!! plugged in but says it is on battery power, wont stop beeping :@
  • 506 Answers
Check the back of the UPS to see if the fuses/breakers are properly closed or open.
Posted on May 28, 2010
Low battery mess changed it and still continues to beep how do i fix
Power your system down first. Plug in the battery, the panel should beep, then plug in the AC power. If the panel doesn't beep you might have a bad battery. If the panel powers up after the battery then AC power reset your time and the beeping should stop.
May 16, 2014 | GE Security Simon 3 Wireless Home Security...
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Thomson 52RW65ES makes beep sound when plugged in. does not work
This indicates a motherboard issue, remove main battery and test, next sub out the ram one at a time testing as you go, if none of these work, the next step is to have a pro evaluate the product.
Apr 01, 2012 | Computers & Internet
My bose sounddock portable system suddenly stopped working so I thought it needed charging, when I plugged it back in to the mains it wont charge and no light comes on the system at all it's totally...
Guys - she has the protable!! Hi Fiona, the best bet is to visit www.invebo.com and check the SounDock Portable diagnostic video. (Repair video is there too) Remove the battery and plug the power in., If you get a beep-beep sound then the unit has power and is booting up so you need a docking connector replacement kit. . If there is no beep beep then it is the power supply or the main unit. (Try a different power supply) . If it works normally then it is the battery - get a new battery. Hope that helps.
Sep 30, 2011 | Bose SoundDock Portable Digital Music...
Why does battery beep and tells me its on battery power when it's stil plugged to wall. and i have a good power source
Usually that indicates a low battery charge or bad battery. Make sure you do not have the battery backup side overloaded with too many devices. Do not plug inductive loads with motors or heating elements into the backup. Turn the device off and unplug anything that is plugged into the bachup. Plug the battery backup into the wall with nothing attached and turn on. Wait 10-15 minutes. this will charge the battery. If beeping continues after this with nothing attached, you likely need a new battery or the control/monitoring system is bad. If beeps stop, reinstall and do not attach more wattage than the unit can suppluy
Jan 06, 2011 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
The Horn wont stop beeping so I took the fuse out now my battery dying every morning.
Most vehicles have relays to run different things and in most cases the relay gets power before the fuse so if you pulled the fuse the relay is more than likely still getting power. It may be that you just have a bad relay. You can also find the horn itself and simply un plug the power supply wire going to it.
Feb 06, 2010 | 2007 Jeep Commander Rocky Mountain
Tv wont stop beeping every time i turn it on. It is a very high pitch beeping that doesn't stop. I have tried plugging the tv in several different plugs by itself but the beeping still didn't stop.
Ur High Voltage is dead.The FBT the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced the FBT get power back.
Jan 19, 2010 | Televison & Video
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Cell phone`
Your battery has had it. You can get a new online for only a few dollars. From what I've seen from alot of the Razr phones the beeping it as just as you were saying. When the battery is dead or does not have enough power to do the basic functions it will beep. The only difference is that, even if it is turned off they will still beep because it has a low battery. have you tried a different battery.
Jan 21, 2008 | Motorola Mobility RAZR V3
APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System Logo
575 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
