Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
Vacuum won't pick up
The dirt devil I have won't pick anything up there seems to be no suction. I emptied the cup also cleaned the hepa filter.
  • Dirt Devil Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on May 28, 2010
I have lost suction on my dirt devil vacuum cleaner, I have looked in the obvious places but can't find a problem. It is only a few months old. Thank you
The loss of suction can be on the output side of the impeller also. Make sure that any filters there are clean especially if it is HEPA
Jan 14, 2016 | Dirt Devil Vacuums
How to replace filter
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
F1 HEPA Filter
Aug 11, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
How do you empty it?
There is a black clip at the top of the dirt cup which holds the dirt cup in place on this vacuum. Pull back on this clip with one hand and with the other you will be able to remove the entire dirt cup assembly. Once the dirt cup assembly is off remove the lid, and take the bottom portion to the trash can and dump. Tap the side of the cup slightly to remove excess dirt. Romove the dirt cup filter inside and do the same. Replace the fiter and the lid and put it back on to the machine. You should replace the dirt cup filter every 6 months to a year. Part is below:
F1 Dirt Devil Replacement HEPA Filter Style F1, Dirt Devil Part 3-JC0280-000 Cost $ 15.95
Apr 27, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Turns on but does not want pick up anything.Suction is good but the garbage does not go into cannister.
The reason it is not picking up is because the belt is stretched or worn. You simply need to replace the belt. you can get belts here:
Dirt Devil Belts
Feb 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Vacuum Problem
The Bissell can have several filters in it, depending on the model. Some have a round hepa filter that is covered with a foam sleeve. This filter is located at the bottom of the dirt cup. Others have a foam filter that is located under the dirt cup in a pull out drawer. Also, they can have a cylindrical separator above the dirt cup which can be removed and washed. They are usually a blue plastic and you reach in and turn it a 1/4 turn counter-clockwise to remove. If your machine has the hepa filter, when you remove the dirt cup, the filter is at the bottom and you turn the bottom 1/4 turn and the clear housing will come off to access the filter. You should also check the small filter on the machine just below where the cup sits. This will only be there if your machine has the hepa filter on it.
Mar 21, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
1,018 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
