Question about Maytag MZD2752G Side by Side Refrigerator
I have a maytag plus model mzd2752gr and it's not cooling enough
I have a maytag plus model mzd2752gr and I'm not getting enough cool air in my freezer or fridge side. My ice maker is also not working. Please help!
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerI have a maytag plus model mzd2752gr and it's not  - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 28, 2010
  • Maytag Master
  • 1,606 Answers
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
Refrigerator temperature won't cool items lower than 41 degrees.I assume this is caused by a faulty thermostat.It is a Maytag Plus model MTB2156AE.
Not necessarily the themostat. It could be the internal fan that circulates the air from freezer to fridge or you have ice blocking the air flow.
Sep 13, 2011 | Maytag Refrigerators
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
Maytag plus refrigerator is not cooling properly freezer works fine model # msd2756deq
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 18, 2011 | Refrigerators
Problem with my refrigerator. Freezer section is working but refrigerator is not cooling. its maytag Plus model # MSD2556AEA.
heatman101
Dec 12, 2010 | Refrigerators
Lack of cooling
Check for blocked filters or coils, both on the hot side & the cool side. It is possible that either is blocked by airbourne dust or debris. This is common in areas with lots of poplar trees.
Jul 05, 2007 | Maytag NMPEB08F2A Air Conditioner
Maytag MZD2752G Side by Side Refrigerator Logo
613 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
