Question about Motorola Mobility RAZR V3
Can't hear can only hear caller if I am on speakerphone. I have tried to turn the volume up as some have indicated, that did not fix the problem
  • saketjaip Nov 28, 2008
    A problem in my Moto Razor where I cannot hear the person I call or the person who calls me unless i put the speakerphone on
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have the cable connected to the lcd replaced.
Posted on Apr 08, 2008
How do I adjust ringer volume on wired ATT two Line phone model 993
VOLUME buttons;
During a call, press to adjust the listening volume.
While the telephone is not in use, press to adjust ringer volume.
Oct 30, 2014 | 3M 993 Two-Line Corded Speakerphone with...
How can I fix my Blackberry 8520 for hear my caller?
Hi Angelina,
Sounds like your ear speaker is pooched. Time to take it in for repair!
May 04, 2014 | RIM BlackBerry Curve 8520 Smartphone
Motorola tz700 echo
Dave. Maybe your phone microphone isn't turning off. Try unpairing and re-pairing.
Mark
Motorola Support
Oct 27, 2012 | Motorola Mobility Tz700 Bluetooth In-car...
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
I can only hear a caller if I turn on the speaker. What's going on?
All the [hones contains two speakers,
1)Headspeaker, Used for hearing from callers..
2)Loudspeaker for hearing Ringtones and callers when on speakerphone mode
THe problem in your case is with the headspeaker,
To check the headspeaker:
UNSCREW THE PHONE TO INSPECT THE SPEAKER.
REPLACE IT, IF IT IS DAMAGED.
TRY USING SOLDERING LED AND SOLDERING IRON TO SOLDER, THE SPEAKER
leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 06, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Speakerphone when answering blackberry pearl 8100
After taking out the battery for a couple of minutes, fixed this on my Pearl
Jan 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
Palm Centro hearing
I hate to sound obvious but have you checked the volume setting? Took me a few days to realize they were there - I almost never read the manual. :) The two volume keys are on the left of the phone as you look at the screen. Hope this helps.
Oct 24, 2008 | Palm Treo 500 Centro
Can't hear caller
The earpiece speaker has gone bad. Unless you have access to a replacement speaker and can solder you will have to take the phone to you nearest Motorola service center.
Sep 05, 2007 | Motorola Mobility RAZR V3
Speakerphone does not work
Try pressing the Feature button and dialing the digit 1. This will turn the microphone on and the MIC lite should turn red. Don't lift the handset or press Speaker, just press Feature 1. This will also turn the MIC off if you want it disabled again.
Nov 06, 2006 | NEC DTU 8-1 Corded Phone
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
