Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
My pen drive is in RAW file system, I ca'nt open or format it.
My pen drive is not opening or formatting, not from my computer or disk management.Its curently having the RAW file system, don't know how to make it better.. please ,please,please help
    Master:
  • 633 Answers
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
Posted on May 29, 2010
Hello, friend! After experiencing similar RAW file system external hard disk data loss troubles, I know the RAW file system drive often cannot be immediately formatted to restore its file system from RAW to NTFS. Otherwise, you may lose something original permanently. Therefore, stop writing anything fresh on this RAW format flash drive and go recover lost data from RAW flash drive with RAW format drive data recovery software. And then, back up all rescued data on another safe drive or location well.
And, at last, format this RAW file system flash drive to see whether it is still workable or not.
Learn to be careful about crucial drive data and make drive data backups well in the future.
Posted on Oct 13, 2015
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
My pn drive shows used space & free space is
see if you can format it if not it is bad
Apr 13, 2010 | Transcend (589307) Media
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
2 GB PENDRIVE SHOWING UNABLE TO FORMAT. AND ASLO
You can try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 07, 2010 | Transcend (589307) Media
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
Nov 17, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
PEN DRIVE ERROR
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Feb 03, 2009 | Transcend (589307) Media
Pen drive can't be formatted
Partition and reformat using Disk Administrator, which is found in Computer Management under Administrative tools.
Dec 31, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
PEN DRIVE SHOWING 0 FREE SPACE AND ZERO USED SPACE
Hi
Just go to My Computer.right click on Manage.Then click on Disk Management.In the bottom tab you can see your pendrive.click on it get a new partiotion using NTFS.
Nov 28, 2008 | Electronics - Others
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
Electronics - Others Logo
818 people viewed this question
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
