Question about Pentax ME Super 35mm SLR Camera
I have a Pentax ME Super that, after sitting for a couple of days, double advances before it catches. After that it works fine until it again sits for a day or two, and then it does it again. Any ideas on the cause? Thanks.
    Brigadier General:
  • 3,006 Answers
It almost certainly is due to sticky dried-out lubricant inside the camera. If the camera has never been serviced then it's been drying out since at least 1984 when Pentax ceased production of the ME Super.
It probably just needs a professional CLA service (Clean Lubricate Adjust) which will then keep it going for a few more years. It's also worth paying a one-off fee to have the foam light seals replaced as they will be on the way to becoming a corrosive black goo by now.
Although most 35mm SLR cameras are near worthless, a recently serviced and foam replaced ME Super will definitely be worth reasonable money. Still not quite as much as you'll have spenton servicing though so only get the servicing done if you intend to use the camera for at least a year to get your money's worth.
DO NOT try to take a cheap shortcut by squirting WD40 inside. You'll instantly ruin your camera.
Posted on May 28, 2010
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
I have a 2000 ford f250 super duty and my engine turns but wont start. It ran fine the other day then i let it sit for a day then try to start it and now it wont start this is the second time it happen to...
possibly the fuel pump check the fuel pressure with a gauge on the fuel rail if its a gas motor, is it diesel if so your in luck cause im a diesel mechanic
Oct 02, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Will not turn on. looks like it leaked water. power light on with no image in viewer.
i had a small amount of water inside, let ir sit for awhile, a day, with no battery or card and the door open, worked fine, used it again in water same problen, day just started, if it revives, no more pool.
Aug 13, 2009 | Pentax Optio W10 Digital Camera
Phone says "out of range"
I'd try pulling the battery on the phone that is out of range and letting it sit for a couple of days. Then plug the battery back in and see if the phone activates. If nothing happens then try putting it back in the charger. My guess is if it's been sitting in the charger the whole time, the battery developed a memory and thinks it's dead.
Mar 11, 2009 | Uniden Cordless Phone
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Film advance slipping?
This has happened with my pentax super program. All that was wrong is the the spool/winder was dirty. It needed to be cleaned. You open up the back of the camera. Stick something such as a small screw driver, just something to stop the film winder from turning. Now turn the top of the winder off while keeping the bottom part in place. Be very careful not to close the back of the camera while you do this. Once you have it out give it a clean with a soft cloth and then put it back in. I found it tricky to align it and get it back through the whole. But, that's me. After that it worked perfectly. Until the next time in a year or so it needed to be cleaned again. Hope this helps.
Oct 06, 2007 | Pentax ME Super 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
111 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
