Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
Liebherr ice maker not working. two wires hanging
Liebherr ice maker not working. Two white wires joined in a sleeve are hanging down into the ice tray. Not sure if the sleeve is a thermo couple/probe or just a joint
  • 210 Answers
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
Posted on Jun 03, 2008
  • 55 Answers
SOURCE: Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
  1. Check to see if water is flowing @ the water inlet valve @ the rear of the unit. You can remove it and clean if out-then put it back in service. You can purchase a new valve -- maybe @ home depot.
Posted on Aug 27, 2008
  • 531 Answers
SOURCE: Blue substance in Liebherr ice maker cubes
flush the water on till it get clean
Posted on Mar 31, 2009
  • 136 Answers
SOURCE: ice maker is not making ice...no water to tray
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Posted on Jul 07, 2009
SOURCE: ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Posted on Jul 24, 2009
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Ice maker not making ice, white cord hanging down
Yes, please unplug it from the wall and insert the 4 wire connector into the back of the freezer.
Oct 09, 2016 | Frigidaire Professional Side By Side...
Ice maker is not making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 15, 2010 | Liebherr European Right Hinge Fully...
The ice maker appears not to be working can not
heatman101
May 31, 2010 | Liebherr KIKNV3056 Bottom Freezer...
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
Wires hanging in ice maker area
Look underneath the 2nd row from left in the ice tray there should be a white plastic piece that pops in and out from the bottom of the ice tray. Pop it off. There should be a piece of styrofoam on top of the piece you removed. the white wire runs along the bottom of the ice tray there may be little plastic hooks to place wire along the way. The sensor should fit right where the white piece of plastic and styrofoam you removed goes. Just place it there and pop that piece back in. It really doesn't attach to anything just lays there.
May 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice Maker
Maybe the wire loss from inside, be careful, don't get electric shut.
Jul 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
584 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
