I purchused a turntable and tried hooking it up to my A/V receiver and nothing is working. any advice on how i can get this to work?
  • 4,234 Answers
Turntables have extremely low outputs and require a phono input on the receiver. If yours does not have one, you need to purchase a phono pre-amp. This will boost the signal to the level required for any aux or tape input on a receiver.
Dan
Posted on Apr 08, 2008
SOURCE:
Technics SL-D33 Channel drop.
There's nothing wrong with the turntable then. It's your receiver that's the problem. In order to hear a magnetic cartridge it has to go via a pre-amp. It's this pre-amp that has failed in your receiver. It's only used by a turntable so wouldn't affect anything else. You should be able to trace this pre-amp by following the turntable socket wires. It will probably be a small IC that has failed. If you look up the number you should find it.
Nov 30, 2013 | Technics Audio Players & Recorders
I recently bought a Pioneer VSX-52 receiver, and tried hooking my Stanton turntable up to it, no sound came through. There is no grounding point that I have found on the receiver, is the not grounding the...
so you have a pre-amp otherwise you aint trying to use otherbinputs
, but the ground cable goes with your sungle phono soursce to the PHONO-preamp and the output is a Line-level , which you should here
Jul 17, 2012 | Stanton STR8-100 Turntable
Trying to hook-up a turntable to sr880. which input works best? also think the receiver is muted, how do i unmute the system?
Is it Marantz???? The Marantz 880 doesn't have an input for PHONO. A traditional turntable will require a PHONO preamp between it and any Line Level input on the receiver.
Muted? Look at the front panel for clues. Maybe sure no tapes or unattached inputs are selected. Try the test tones to prove it works.
Mar 27, 2011 | Audio Players & Recorders
Will I be able to hook up a turntable to this?
no/ turn tables dont have passive sound output unlike dvd players they need a connection that is 200% more powerfull than an dvd input the only and cheapest way to fix this problem is to buy a cheap audio mixer plug the turntable into the phono of the mixer and the mixer ouput into the video input and it will work great need more advice feel free to email me
good luck
Jun 25, 2010 | KLH R5100 Receiver
Why wont my turntable work? it works when hooked up to other receivers. i get nothing
Most new receivers don't have an input for PHONO. If yours doesn't you will need a phono preamp between your turntable and your receiver. Cost about $30.
May 26, 2010 | Mitsubishi M-VR700
Can't seem to get any music from the turntable
Do you have the ground wire from the Turntable hooked up to the receivers ground terminal? it's a screw down silver nut and should be next to the Phono input. You are just lacking a ground from the turntable to the receiver. If you don't see a wire from the turntable, look around the chasis of the unit and you will fins it. Hope this helps
Jun 21, 2009 | Yamaha HTR-5740 Receiver
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
How to hook up my turntable to my RCA home entertainment system
http://www.htfr.com/more-info/?catno=MR155277.
please buy the item above -----connect your turntable to input and take the output and connect it in line in in receiver.
Aug 11, 2008 | Audio Players & Recorders
Hookup
what turntable specifically....
jeff
Feb 22, 2008 | Denon AVR588 Receiver
No Sound from Turntable
It definitely has to go through a preamp (a PHONO preamp that is...) something like this: http://www.phonopreamps.com/tc400pp.html
Sep 14, 2007 | Nakamichi AV-7 Receiver
101 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
