Question about Mtd 22" Yard Machine Push Mower
Running problems with Mountfield HP454 petrol lawnmower
The mower starts OK in choke mode, but cuts out after a few seconds. If I start it in fast mode, it sometimes fixes the problem for a while. The engine also stutters a lot so it seems like there might be a problem with the fuel pump?
  • Anonymous Mar 16, 2014
    I fitted a new magneto unit to my outfield hp454 mower and need the spark gap
  • 279 Answers
First thing to check is the air filter. It may be plugged.
Posted on May 28, 2010
Why does my Mountfield Petrol powered lawn mower cut off instead of idling while I empty grass cuttings?
what engine does it have, how old is it and does in not have a bar you have to hold in to start/stop the engine?
Mar 07, 2015 | Garden
Dear Sir, I have an Mountfield m4 major petrol lawn mower some 20 years old. It starts O.K. but the engine will stop after a few minutes.By turning the choke on just before the engine stalls, will keep it...
sounds like the needle valve Seat is slightly clogged and the gas entering the Carburetor cannot keep up with the Draw from the engine.
Oct 05, 2013 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
I have a honda gv100 lawn mower and there is no petrol going to the engine
I have a mountfield omega petrol lawnmower with a gv100 honda engine. I turned it upside down to replace the blade and now it won,t start. Any help would be appreciated
May 30, 2010 | Honda 8 HP Engine
Just bought a mountfield sp454 mower filled it with petrol the petrol then started to pour out of fuel bowl there was a plug missing fitted a small bolt in the hole then started the mower it felt as though...
Get he model, type and code off of the engine shroud and take them to your local small engine parts dealer and get the proper bolt for the fuel bowl. They use a special bolt that is hollow and with a weep hole for the gas to flow through the inside of the bolt and up into the carb. Get the right bolt and it will most likely run for you.
good luck
roundo4
May 23, 2010 | Garden
My troybuilt yard pony riding lawnmower will start with the choke fully open and then dies immediatly when you take the choke off. It will only start and run with the choke fully open, but dies after 20-30...
Do you mean that you can start it normally using the choke (that would be choke CLOSED), but then it dies immediately when you move it to run (that would be choke OPEN)? And if you leave the choke in the starting position that it dies after 20-30 seconds?----- If I have that all right, then you definitely have a restriction in the gas supply. Drain all of the gas from the mower and don't use any old gas. If you have any more old gas (from last season) don't use it. If this mower has a gas filter, replace it. Put just a little fresh gas in the tank plus a little of the cleaner. Start it up, do that a few times if needed. Use a fuel additive such as Sea Foam to keep the gas from gumming up so fast.
Mar 15, 2010 | Troy-Bilt Garden
Lawn mower wont start
I have the same mower and I have the choke assembly complete, I will take a picture for you if you want to show you what should be there? Mine wont start at the moment wondering wether its the magneto
stu
Jun 27, 2009 | Garden
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Mtd 22" Yard Machine Push Mower Logo
1,752 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
