Question about Kitchen Ranges
Amana Stove: Model # AER5715QAS Stove stays hot long after it is shut off. It was used at 400 for 40 minutes. 3hrs later is was still hot. I metered the power and check to see if the elements came on. Everything is normal. I opened the door to see if it would make the elements come on and it dont. I got the temp cool with the door open and when I closed the door it started heating up inside without any elements or anything coming on.
  • 17,970 Answers
Check your Keep Warm settings, its possible that are activated, or, any fault code there. Check ot.
Also can check this Amana Stove AER5715QAS - Service Manual Part 1 and Part 2
Posted on May 28, 2010
  • Gene Strote May 28, 2010
    The keep warm setting is off. I am confused because the power is fine and the elements dont come on. How is it even possible for the oven to get warmer when the oven is off?
  • ZJ Limited
    ZJ Limited May 28, 2010
    I suggest make one electrical diagnostic with checked continuity voltage when your device is OFF (but connected to power); any relay keep close the circuit or working bad, keeping voltage there.
Add tension to loose oven door amana gas model args7650ss
Hello. You will need to replace the door hinge assemblies. The part numbers are as follows:
Right hand hinge 31715202
Left hand hinge 31715201
I hope this helps you.
Aug 14, 2015 | Amana Kitchen Ranges
I have an Amana stove model ART4002W. The oven will not heat above 250 degrees and the broiler element will not turn on. I replaced the broiler element and the heat sensor. No change.
if you have it on broil and the element doesn't heat up and you changed the element then you either have a loose or broken wire or a bad clock assy. part number 74009213 and it's around 166 dollars
Feb 11, 2011 | Amana AER5715QAS Electric Kitchen Range
Preheated stove put in cake a few minutes later smelled burning and cake was burnt on top.. Broiler was on and running hot as heck. tried turning off stove but would not shut off.. Unplugged. Let satand to...
Probably the control relay has shorted. But first check the voltages at your receptacle to insure that a neutral is not floating. You should fine 120 from each hot to the neutral.
Jan 09, 2010 | Kenmore Kitchen Ranges
I have Toshiba TV Model #65HM167. The problem is when I turn it on - it will stay on for 30m to 3 hrs, and then just shut it self down. I pull the power cord for 30 minutes and then plug it back in and it...
check the fan to make is working properly. It's in the lamp compartment on the left side of the unit. clean the vent on the rear unit and the fan fin's gently. good luck
Dec 13, 2009 | Toshiba 50HM66 52" Television
My oven does not shut off.
Hi there, this is a serious control fault that may be fixed by unplugging this unit for a five minute period. after this hard reset, plug the unit back into the wall outlet and power up. if the unit continues to stay on, you will need to replace the control(electric oven control)board.
May 18, 2009 | GE Kitchen Ranges
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
