Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
I have a f7227-900 hoover steamer and this is the third time in the year and half that I have owned it that it will be taken back to the shop, the brushes quite spinning, I don't use it that much, can you please tell me if their is something I can do to not have to haul this machine into town and have another $70.00 bill.
  • 4 Answers
I have the same Hoover f7227-900 I believed that the gears are worn out. you will need to replace them. That would be the Turbine Gears. They are made of a hard plastic.
Posted on Jan 22, 2011
My brushes on my hoover carpet machine f7227-900 stop spinning and then started again and now they are not spinning any ideas.
Thanks Joe
Posted on Dec 30, 2010
Hoover advance path steamer practically new started smelling like burning now won't turn on
Service Center Locator - Hoover
hoover.com/locator/
The Hoover CompanyFloormate Scrub Cleaners · Steam Cleaners · Stick Vacuums · Carpet Cleaners · Parts & Solutions · Search Parts · Bags · Belts · Filters · Cleaning Solutions.Missing: advancepath
Hoover steamvac repair - YouTube
? 6:16
https://www.youtube.com/watch?v=cyenpuw2XyM
Apr 23, 2014 - Uploaded by BCtruck, rebuild, repair,repurpose
Its ben two years since we had the carpet in the sunroom steamcleaned. It pains me to pay someone else to ...
Nov 07, 2015 | Hoover Vacuums
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
My Hoover Whisper Cyclonic is collecting the dirt but not taking it into the cylinder. The brushes were at one point starting and stoping due to the belt periodically turning,now the brushes are turning...
You need to change the belt once every year. It's a good idea to take it to your local vac shop and have it serviced once a year also. They can fix this for you. Your belt is worn out.
Jun 30, 2017 | Hoover U5753-900 WindTunnel Bagless...
Power just 'clicks' doesn't turn on.
The motor could be burned out or you have a carbon brush in the motor that is stuck. The motor will need to be taken out and tested on its' own. A electric motor company can test it for you or a Vacuum Shop.
Dec 03, 2009 | Hoover Vacuums
I have a Hoover Steam Vac. Even though I don't
There in the trigger assembly is a release button that might be broken.
Nov 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
My Hoover Windtunnel cuts off after using it for a few minutes. After an hour or so, I can turn it back on again. This keeps happening every time I use it. This is my third one. I have taken the other two...
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
May 30, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover U5507900 Elite Rewind problem
May have to replace the cord reel asm. It will have to be taken out and inspected, if can't see a problem, then replace it. If this is less then one year old, then it is still under warranty and should be taken to a warranty shop along with proof of purchase.
Dec 31, 2007 | Hoover U5507900 Elite Rewind Bagless...
Dirt cup lock on windtunnel vacuum won't lock
It may have to be taken off and then re-installed, but if it is only 1 and 1/2 old, then it is under warranty. There is a full year on Hoover vacuums. Just take proof of purchase with you and take it to a warranty repair shop. You should have their 1-800 to call and find the closest shop. Warranties are void if you temper with it.
Nov 10, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
176 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
