Question about Frigidaire Refrigerators
Frigidaire FRS6L9EFSS4 Side X side Flashing 4 where temp should be on fresh food side.
22yooper
  • 828 Answers
SOURCE: freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
Posted on May 22, 2008
  • 110 Answers
SOURCE: GE side by side not very cold on fresh food side
there is one of two thing that could be going wrong here ; you may have a bad evap fan mtr and control board or yourr damper is not opening properly. i would say you have the later of the two due to the fact the rf is still making ice. one thing that causes this issue is too much weight in the door causing the door to lean and not trigger in door light switch or the switch itself is damaged. the door hinge and camm assembly can be adjusted from the bottow using a standard socket set
Posted on Jun 13, 2008
SOURCE: fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Posted on Nov 12, 2008
heatman101
  • 43501 Answers
SOURCE: Frigidaire side by side not
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
leecom72
  • 4806 Answers
SOURCE: i got a frigidaire phs66ejsb0 and in the digital
As far as i know this means the damper failed the start up test which is producing the error code 4. It could mean the replacement of a circuit board that controls the temperature as the H2O filter may have leaked and shorted it out.
You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature
control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and
hold it for three seconds.
Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops.
To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds and see if that resolves the problem.
If not then you will need to contact Frigidaire themselves for advice on how to resolve this problem or to have and engineer come and take a look at it for you.
(United States)
1-800-944-9044
(Canada)
1-800-668-4606
Good luck.
Posted on Jun 26, 2010
Why does the fridge side of my fridgidare side by side keep flashing on 4
FFHS2622MB3 FRIGIDAIRE REFRIGERATOR Manual ...
www.searspartsdirect.com > Kitchen Appliance Parts > Frigidaire Parts
Download Manual for Model FFHS2622MB3 FRIGIDAIRE REFRIGERATOR. ... ShopFor Parts. Click a model number to find parts at Sears PartsDirect.
Jul 28, 2015 | Frigidaire Refrigerators
Repair flashing light in refrigerator model frs6hr5hsb6 flashing number4
A flashing four (4) is indicative of a damper circuit issue. It is either the damper or control. Unplug the unit and open the fresh food door when you plug the unit back in you should hear the damper move If it is really loud it is bad. You can drop the control, it is held in place with 1/4" screws and observe the movement or lack of. If the damper is operational and not noisy replace the control with the flashing four(4).
Feb 18, 2015 | Frigidaire FRS6HR5HB Side by Side...
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Can you tell me what a flashing # 4 means on the fresh food display,when I try to set temp.the flashing # 4 keeps coming back. the fridge temp. is too cold and freezes everything.
Hello Bryce,
I found a manual, although I cannot be sure it is for your exact model, it is located HERE. This is what is stated under "Temperature Adjustment"
IF TEMPERATURE DISPLAYS FLASH... If ever you see both temperature displays continously flashing, it may indicate that the control system has detected a performance problem. Call your service representative, who can interpret the flashing message. To maintain temperatures, a fan circulates air in the refrigerator and freezer compartments. For good circulation, do not block cold air vents with food items.
This is located under "Turning the Cooling System On and Off"
TURNING THE COOLING SYSTEM ON AND OFF You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and hold it for three seconds. Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops. To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds.
If the manual I selected is not the one for your particular machine, there are others located HERE. There are various ones only differing by a "upgrade" letter on the end, perhaps for different models of different manufacturers, produced by the same company.
I hope this is of some help
Joe
Sep 20, 2011 | Frigidaire FRS3R5EMB Side by Side...
What temp should the frezzer be and what temp should fresh food side be
hello, the standard temps are zero in the freezer and 38 in the fresh food side. Hope this helps.
Jun 07, 2011 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
Temp display (fresh food temp) has flashing # 4. Any idea's? Mod# GLHS36EFSB1 - side by side fridge
my Frigidaire showed the number 4 on the display after power outrage. And the temp is really warm inside. I unplug the power and plug it back 1 minute after. now I can set the temperature and it's working fine.
Mar 26, 2010 | Frigidaire GLHS36EESB Side by Side...
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
Fresh food side freezing
Nov 06, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
104 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
