Question about RCA D52W136D 52 in. TV/DVD Combo
Cant find convergence in setup
We cant find control for convergence in setup use to be there now gone
  • RCA Master
  • 8,457 Answers
There are three small rectangles sqaure boxes cap fuses parts(FL231) the one in the middle is dead.Replaced the one in the middle located right side near of the big black block of plastic call FBT.U know how to do soldering and have the equipments?Try website like Ebay.com to the cap fuse part(FL231) fuse.After the cap fuse(FL231) is replaced the Convergence well return,ur tv back to normal.
Posted on May 28, 2010
  • Chi Chu May 28, 2010
    Go to Ebay.com type in Convergence Fuse FL231.Buy this fuse in bulk.Because this fuse burn often like about 6 to a year of this RCA tv use.
I have a casablanca fan no pull chain or switches on fan wired ok power on remote control gone is there ca universal remote i can buy ??
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 18, 2013 | Casablanca Fan Televison & Video
Why cant i manually adjust the color convergence
The thought is that the Amplifier that controls this color has gone bad. If you tweaking the Global L&R Horizontal knob and nothing is happening. Then the amp is shot.
May have to replace the Amp or the whole board.
Blessings,
A/V Media Tech Guy
Nov 23, 2009 | Toshiba 50H82 50" Rear Projection...
Can you manualy fix the covergance arrows one by one flash focus wont line up had controll replace and stiil wont work the tv repair guy said he needs to fix covergace switches one bye one but the model...
if your talking about a samsung set, then probably the convergence modules are gone. there has`nt been manual convergence setup controls for more than 10 or 15 years i think
Oct 30, 2009 | Televison & Video
The R, G and B guns on my rear proj tv have gone out of alignment and I am unable to re-align them. I suspect a major control board has gone south forever. Is it worth fixing?
Your symptoms sounds like it may have damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
3d image
This is what known as a convergence problem. First question is in your setup menu do you have a convergence option.. if you do then do you have any control in that mode does the crosshars move up and down and side to side... if you dont then you have a convergence power supply issue.. if you do it could be a setup issue. IF you do not have convergence in your setup menu then it possiblely be a special fuse.. and bad electrical connections. so let me know and ill see if we can narrow it down further
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Warped picture and looks like you need 3d glasses
Check FL1231, DP1231 and C1230 on the deflection board thats usually what causes the option to drop off the menu
May 10, 2008 | RCA R52WH76 Television
Convergence
by the convergence menu i would assume you mean in the customer setup menu. although i have seen this at the shop on newer itc222 i guess it can happen with older sets...is the convergence gone...is it red green and blue.. if not it might be cut off in the service alignment menu...if that is true. how did it get cut off. has the set been worked on?
Feb 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
RCA D52W136D 52 in. TV/DVD Combo Logo
124 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
