I put a load in but the water did not pump out and when I took water and clothes out of the machine, the machine would not spin. I am not sure if the aggitation cycle works, but the machine can fill with wter. That part works. The machine is a Kenmore, stylemaster #909957
  • Washing Mach... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineI put a load in - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 28, 2010
When i put my machine on to spin the clothes are coming out very wet, I have cleaned out everything, everything seems to be working properly, The pump is fine, Can you tell me what is wrong I use onl
Depends how old your machine is Sounds like your motor maybe wearing out. Does it make any noises. Make sure your not putting in to many clothes weighting it down. Try spinning a very little load see if they come out ok. If not MOTOR.
Jan 21, 2015 | Washing Machines
Won't spin, just agitates. Clothes and water still in machine !!
Glad to hear of progress.Pump could be faulty. 1st you need to check nothing is stuck in the pump ie..coin, next make sure the filter is clean, now is the pump blade free to turn by hand if not investigate why. If all okay replace pump if satisfied there is no blockage and water is flowing to the pump,worthwhile at the final stage to make sure final drain hose to waste pipe is clear..Good luck if I can help anymore please ask...
Nov 20, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water not draining
The belt may have failed due to the pump seizing up.
Remove the belt and turn the pump with your hand. If the pump seems hard to turn (should turn freely) replace the pump.
Jun 25, 2008 | Maytag SAV4655A Top Load Washer
Gibson front load washing machine will not spin
are you sure the pump is plugged up and was the impeller damaged
Mar 29, 2008 | Washing Machines
Frigidaire Affinity Front Load
Mine wouldn't spin out the cloths very good,,they were real heavy and wet. I took the lines off of the pump and pulled it off,,,to my suprise,there was about $3 in change in the pump...cleaned it out and put it back together and it works great again. no idea what that had to do with the spin speed,,,,but it worked.....just an idea
Dec 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
