Question about Dell Latitude C840 Notebook
What is extend ram capacity
I upgraded RAM from 512 MB to 1024 MB ram but my notebood not accepting it.. on each start it asked for F1 command on starting
  • 180 Answers
There are a lot of reasons your laptop is not accepting the new memmories
1) If it is an old laptop the motherboard might not support upto 1 GB of memmory
2) It can also be due to the fact that the connections are loose and the ram is not properly inserted or dust is interfering the contact
3)It can also be due to the difference in frequency and latency of the new ram you inserted
4)it can also happen when the frequency of the ram exceeds the frequency supported by the Front Side Bus(FSB)re it is compatible and also ensure that it is properly fixed
Check the ram ratings and make su
Posted on May 28, 2010
    Problem Solver:
  • 5 Answers
Fyi the dell latitude c840 will support 2 gb of ram pc 2100 sodimm ddr also up to 2.5 cpu and at least a 160gb hard drive and at a spindle speed of 7200 rpm look aroubd and you can find most of this fairly cheep my c840 has this and a bit more it is by far much faster and multitasking is no problems and playing games is a breeze even though it is an older machine dont sell the c840 short it can be upgraded quite a bit if you choose to do so also it will run windows 7 with no problems
Posted on Apr 14, 2011
Will Mercury 810e motherboard support 1.0 GB (512 MBX2) SD RAM?
I cannot directly answer that question because you did not supply the motherboard model number. You will have to look this up yourself, here is the url for Mercury support
http://www.mercury-pc.com/downloads.php
The model number is usually printed on the motherboard, find it and you can download the manual, specs and drivers.
Mar 06, 2017 | Q-Lity 810E-T (P3810E-T) Motherboard
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
Helo, i want to upgrade memory on my ASUS CUBX-L motherboard. Manual says it recive max 4 x 256 MB of SDRAM. Is it possible to put 512 MB or bigger RAM modules?
yes you can put 512 mb of ram even 2 of it because the capacity of your board is up to 1024 mb of ram but make sure that it is an sdram and it has the same specification on whar is your manual indicate besides on the ram size.
Oct 14, 2010 | ASUS Intel 440BX Chipset CUBX-L...
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Install Ram upgrade for HP Laptop Pavilion
Maximum memory capacity is Up to 1 GB (1024 MB) SDRAM using 512-MB modules.
Mar 27, 2009 | Computers & Internet
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Ram capacity?
256-MB SODIMM in slot 1)
1024 MB (133 MHz) SDRAM
512-MB SODIMMs in slots 1 and 2
Jan 05, 2008 | Compaq Evo N600c Notebook
Dell Latitude C840 Notebook Logo
91 people viewed this question
Alun Cox
