Question about LG LMV1650SW Microwave Oven
What size fuse is a 250v 10a drawing fuse inside my microwave would a 6.3 32mm fuse be ok.its a lg ms-283 mc microwave
  • LG Master
  • 9,098 Answers
Chances are it is a standard 1/4" x 1-1/4" (6.3mm x 32mm) but I would suggest measuring it to be sure.
Here's an exploded view of that oven to help in disassembly.
Posted on May 30, 2010
I have a lg microwave oven model mc-2681ds stopped working the service centre people say its circuit board needs to b replaced . coz of 6-7years old model the company doesnt have its spare circuiT.
Before you dump it, if it is totally dead with no lights or anything, I would check to make sure that the fuse inside is okay. Make sure that the unit is unplugged and turn it around and take the screws out that hold the cover in place and then remove the cover. Look for where the power cord goes into the back of the microwave and follow the black wire from the cord to wherever it ends. It should end at either an inline fuse folder or at a small circuit board. If it goes to a board, your fuse will be mounted on that board. Remove the fuse and have it checked with a multimeter set for continuity. If it is bad, replace it with the same size fuse, you will find the size stamped on one of the silver bands at each end of the fuse. It will be either a 15 amp or 20 amp fuse usually. If you put in a new fuse and it blows right away, that means you have a short somewhere and you would need to have a repair tech look at it. Hope this helps!
Jul 02, 2015 | LG Microwave Ovens
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
Lg microwave ms-428md does not heat up food
8 or 10 or 12 amp fuse inside is worth checking but it is not a normal fuse Re: Jeff
Apr 12, 2012 | Microwave Ovens
Microwave Oven has died
Hi.
Check continuity of this 10A fuse to see if it's blown.
What is most likely to have happened, is that an internal short has happened inside the main transformer. These cannot be rectified, and often means scrapping the complete item due to cost of replacement.
However - if you can find another microwave with a different fault - just remove the good transformer.
Checking the transformer for a short at high voltage is not recommended.
You could try a spare 10A fuse as a start point (probably a leaded type) - but expect it to blow again. DON'T go higher or omit !
Sep 30, 2009 | Microwave Ovens
I need a new fuse for my Galanz Microwave. its a 15amp ceramic 250V fuse. small size
jut click here and you'll be redirected to retailrs website's exact page
http://www.thefusecompany.com/index.php?cPath=36
Jun 11, 2009 | Microwave Ovens
Panasonic NNA554W blows 10a fuse when microwave comes on
Possibly the interlock monitor switch is bad or out of adjustment. This switch is designed to create a short circuit across the power line (and then blow the fuse) if you attempt to defeat the door interlock and operate the oven with the door open. A shorted capacitor or diode could also cause the fuse to blow. Because of lethal voltages inside and the possibility of microwave leakage if repairs aren't done correctly, you are best off leaving microwave service to professionals.
May 15, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave stopped working when i pushed the start button
Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type www.google.com and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | LG Microwave Ovens
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
The main 10A 250V Fuse keeps on blowing up everytime I use my Microwave function. This does not happen when I use the Convection Oven.
Possibly magnatron to earth fault.Needs testing profesionaly.(microwaves can kill even when unplugged.)Regards grandadfixer
Oct 15, 2008 | Microwave Ovens
LG LMV1650SW Microwave Oven Logo
234 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
