Question about Cobra 19 DX IV CB Radio
Noise on cb when truck is running
Hello i have a ? when my truck is off completley my cb is fine no motor noise but yet when i start it up i can hear the fuel pump turn on then a noise i guess coming from the engine. Now i have the cb wired up to my cigarette lighter instead of plug in like most. I was wondering what up might think is the problem. Any answers would help, thank you for reading
im installing a in line noise filter on my power to the battery this might help too
Posted on Apr 09, 2009
You might try running an insulated wire and ground directly from the battery.
Posted on May 01, 2008
Motor making noise
Has a timing problem,if it has a distributor check rotar arm.
Jan 27, 2014 | 2003 GMC Safari - Passenger van, with...
My radio transmitts fine. But when I key another CB, my CB makes a loud noise as it trys to receive. Plz help.
hello what do you mean by a loud noise ,how close are you when you key another radio please try and give more info i will help you the best i can
Jan 09, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
Hello, I love my sd600 had it 4-5 years.... last week it started making a noise when the lens is extending or retracting....it still works fine but I am puzzled by the noise... is camera on its last leg....
Hello Dave.
The sound which you are hearing is the the lens motor. When you can start hearing an unusual noise hear, i would suggest that you take your camera in to your nearest repair shop, before any further damage is done.
The next step will be a lens error.
Hope this can be of help.
Kind regards
Andrea
Sep 17, 2010 | Canon PowerShot SD600 Digital Camera
Worked just fine in My big truck, but I upgraded to a BIGGER Radio and have installed my Cobra 29 LTD in my wifes truck. Used a mount and screwed it to the bed of the truck. Has 18' Coax, new mic., 3 ft...
is she getting bad motor noise? Make sure the ANL is on. Is the antenna tuned for best SWR? if the antenna is not tuned it can effect the receive.
Sep 14, 2010 | Cobra 29 LTD CB Radio
Cb is fine when vehicle is off , but when vehicle is running it feeds motor noise back threw my cb?
There are several things you can do to help limit motor noise interference but first you have to figure out if the noise is coming from the power wire, or the antenna system. Here is how to do that.
  1. Start the car, and turn on the radio.
  2. Trun the squelch off so that you can hear the interference.
  3. Unscrew the antenna coax from the back of the radio.(make sure that you do not key the radio at this point. It is bad to key a radio without an antenna hooked up.)
If the noise goes away when you unplug the coax, the noise is getting in from the antenna system. It's either getting in from bad coax, poorly grounded antenna, or position of antenna. For instance, if its mounted on the back of the truck some times it picks up the fuel pump noise.
If the noise is still there then it is coming in via the power cable. If this is the case then there are a few things you can do.
First. Make sure the radio has a good ground. Next, run the power wire right to the battery. This eliminates most noise. Twisting the power cord helps cancel out some noise. And a knot right at the plug end of the cord also helps. Lastly, if the noise is still bad you can get a power wire ground loop noise canceling unit. This stops most noise.
Sep 08, 2010 | Midland 1001Z 40-Channels Base CB Radio
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra radio getting noise from antenna, how to
That post was meant to be the solution, sorry.
Oct 27, 2009 | Cobra 19 DX IV CB Radio
96buick lesabre custom noise coming from tank fuel pump?car runs fine.you can hear noise when you turn key before starting and after starting?3.8liter v6 133000miles,started making noise like a small motor...
fuel pump getting weak -change fuel filter first may be getting restricted making pump work harder but99% pump is just getting old-may fail soon
Sep 19, 2009 | 1996 Buick LeSabre
03 eclipse GTS, automatic, 3.0 L V6, I hear a noise behind me, in the cabin, when I start the car. If I turn the key to "on" but do not start the car, I hear the noise for a short time then it stops. A...
do you have a broken power antenna?if so the antenna motor is making noise with the broken antenna mast-if it is not related to the antenna-need more info.on what kind of noise you are hearing
Aug 09, 2009 | 2003 Mitsubishi Eclipse Coupe
Can not hear people through static from radio.
no,its in the radio.i have had a lot of radios,and i have had several with just too much noise.its in the radio.i would not go by what a trucker cb shop says.contact company,or try and sell it and start over.i have had to do that also.
Feb 15, 2009 | Connex 3300 240-Channels Base CB Radio
Cobra 19 DX IV CB Radio Logo
169 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
