Maytag Insignia hot water dripping only (5 yrs old)
After the rinse/spin is done, only the hot water is dripping. Once I turn off the hot water line, it stops. I might have to repair a water seal? Is there a part number for me to order to repair or have to call technician?
  • 164 Answers
Sounds like the diaphram in the water inlet valve is going on the hot water side. you need to replace the whole valve. turn off water and remove hoses. remove the housing that holds the valve and remove the valve. replace and reassemble.
Posted on Apr 14, 2008
SOURCE:
Washer tub fills after wash is done; hours after! 4-5 inches of water the next day
http://www.searspartsdirect.com/part-number/205613/0026/464.html?modelNumber=LAT9593AAL&categoryName=Residential%20Washers&brandName=MAYTAG
This is the water valve your model calls for.
Sep 24, 2017 | Maytag Washing Machines
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
Water is going into the washer very slow during the rinse and spin cycle, also not carring the softner into the machine
Machine is not that old, the wash cycle water intake is ok? maybe bad water inlet valve? try seeing how it works on only cold and only hot water, change the hose lines from hot to cold and see what happens? as for the fabric thingy may have abad clogged line or a tiny hole in line and its going elsewhere
Sep 21, 2014 | Crosley Washing Machines
My machine has recently started not completing a full wash cycle and seems to stop before the rinse and spin completion. It also shows a "nf" in the digital readout. any ideas?? Of course I cannot find...
Look carefully at supply water. sometimes hoses are reversed, dad wants to save money and turns off hot, but water is needed to finish rinse cycle....turn on both taps and test again.
Sep 06, 2010 | Maytag Washing Machines
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
Dial doesn't advance to next cycle
if u can advance it manually and it works u need a timer if not probably a lidswitch
Mar 27, 2009 | Maytag Washing Machines
I HAVE WATER DRIPPING INTO THE TUB FROM THE RINSE SPROCKETT
hot or cold? the water inlet valve may be cracked or lose...not that hard if you are a handy person!
Dec 05, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Water dripping into tub
One of your water solenoid valves are either going bad or stuck open with a little sediment. Find out which is leaking by turning off one of the water lines to the washer. If after it is turned off it still leaks try turning the first water valve back on the turn the other water valve off. This will help you determine which solenoid valve is having the problem. Once identified it is easily replaced.
Jul 30, 2008 | Maytag Atlantis MAV8551 Top Load Washer
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat strange...like its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Apr 13, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
