Question about Toshiba Satellite L305-S5924 Laptop
The battery won't charge. The power cord doesn't seem to be making a connection
  • 560 Answers
Hi. Remove the battery, plug the power adapter/charger then power on the laptop. If it turn on - your battery is dead. If it doesn't, you need to test the adapter.
You need Volt-Ohm-Meter (VOM) tester to see if your power adapter has power and if its correct as indicated at the back of the adapter.
If you don't have VOM tester, borrow a good power adapter/charger from a friend. If you can't find the exact model, an adapter with the same power jack size, output voltage and ampere will do. Then test if your laptop will charge.
If still did not work, the problem may be in the power jack connection on your motherboard and power IC. I would suggest to bring your laptop to an authorized service center to avoid further damage but if you prefer to do it yourself, just let me know so I can send you more instructions.
Posted on May 28, 2010
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Acer extensa 4620 z will not power on have a new ac adapter and power cord . i can charge battery and charge battery light comes on but push power button and nothing
Try the following, one at a time.
- Remove battery then connect power cord, then power on
- Remove the memory modules then power on
- Remove the other optical drives, then power on
- Remove other components, then power on.
This process is to illiminate the faulty component. It is possible that one component is faulty and is causing shortage that's why your laptop won't power.
If this doesn't work then you need to remove the internal components like hdd.
Hope it helps.
May 08, 2011 | Acer Computers & Internet
Toshiba Satellite L305-S5924 Laptop Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
